Hi, Rochat_Joël
The at91rm9200's mac is store in EMAC register after booting. Your BSP might change it. If the MAC changed after BSP init it, this sounds like a hardware issue.
Thanks & Best Regards!
Ray. xr at trasin.net
2007-11-21
----- Receiving the following content -----
Receiver: rtems-users
Time: 2007-11-21, 18:43:06
Subject: Always network trouble
>Hello,
>I try to make the ntp test running on my board with the csb337 bsp. When I
>debug The execution I can watch ifconfig structur. In the structur there is
>a member called hardware_address, this membre contain an address for exemple
>0x20153752 and at this address there is the correct informations about my
>MAC address (matching my networkconfig.h file).
>When I run the exemple I can watch the response of the ntpserver in ethereal
>but in the packet my mac address is empty !!!
>do you have an idea ?
>Think you !
>Joel R.
>_______________________________________________
>rtems-users mailing list
>rtems-users at rtems.com
>http://rtems.rtems.org/mailman/listinfo/rtems-users
