RTEMS JTAG debugging with ColdFire MCF54xx via Ronetix
Chris Johns
chrisj at rtems.org
Tue Nov 27 22:08:56 UTC 2007
Evgeny Belyanko wrote:
> Is it any idea, how Ronetix JTAG works with RTEMS tool chain?
> Hardware platform is MCF54(7|8)x.
> http://www.ronetix.at/peedi.html
The RTEMS provided GDB supports the standard remote protocol. RTEMS uses the
standard FSF source base and the rtems-4.9 version of GDB also supports the
expat XML library which is required by some remote stubs. In other words RTEMS
support the standard GDB remote protocol.
The user manual supports gdb via the remote protocol. You will have to contact
the supplier to handle the specifics of using the device.
If you use the device and have any specific detail that would help other RTEMS
users a Wiki page if often a good idea.
Regards
