RTEMS JTAG debugging with ColdFire MCF54xx via Ronetix
Wed Nov 28 14:12:17 UTC 2007
Chris Johns wrote:
> Evgeny Belyanko wrote:
>> Is it any idea, how Ronetix JTAG works with RTEMS tool chain?
>> Hardware platform is MCF54(7|8)x.
>> http://www.ronetix.at/peedi.html
> The RTEMS provided GDB supports the standard remote protocol. RTEMS uses the
> standard FSF source base and the rtems-4.9 version of GDB also supports the
> expat XML library which is required by some remote stubs. In other words RTEMS
> support the standard GDB remote protocol.
> The user manual supports gdb via the remote protocol. You will have to contact
> the supplier to handle the specifics of using the device.
> If you use the device and have any specific detail that would help other RTEMS
> users a Wiki page if often a good idea.
It looks very similar to the Abatron BDI2000 from the user's manual.
That was pretty easy to use with gdb.
If you can get Chris and I ones, we will be happy to test them for you. :-D
--joel
> Regards
> Chris
> rtems-users mailing list
> rtems-users at rtems.com
