panic error with powerpc/virtex BSP
Pierre Kestener
pierre.kestener at cea.fr
Tue Oct 2 08:55:16 UTC 2007
Hello,
I am having problems in running the RTEMS helloworld example on a ML405
board (very similar to ML403). I made the FPGA design with the Xilinx
EDK tool and then modified the xparameters_dflt.h that is in the RTEMS
BSP with the one generated by EDK.
When running the helloworld, i receive the following output:
opb_intc_init: mask = 0x7
rtems-4.7.99.2(PowerPC/PowerPC 405/virtex) PANIC ERROR 5
system stopped, press RESET
I am not sure to what refer the number 5 as a PANIC ERROR. Has someone
an idea of what could done here ?
Thank for your help.
Pierre Kestener.
