[Skyeye-developer] Now csb360 BSP of RTEMS can run on SkyEye
Wed Oct 10 15:37:00 UTC 2007
This didn't show up on the RTEMS list because you aren't
subscribed from the sending email address so I am making
sure the reply goes there. :-D
Michael.Kang wrote:
> Hi:
>         After fix some bugs of coldfire 5272 simulation in SkyEye, now
> csb360 BSP of rtems can run on SkyEye. Only hello testcase of csb360
> is tested on svn head of SkyEye.
>       The attachments are output result of csb360 and the
> corresponding skyeye.conf for csb360.
Yeah!!!  That means the console driver is working.
Ticker running will indicate that the counter/timer used by the
BSP for the clock tick works.
Does Skyeye support the network controller on the 5272?
The csb360 BSP does support the NIC on this CPU.
I am adding your configuration file to
http://www.rtems.org/wiki/index.php/SkyEye
and updating the status.  If there is anything wrong or out of date
on that page, please feel free to update it.
This is great news!!
--joel
> -- Thanks
> -- MIchael.Kang
> CLinux.org Websites:
> http://seohelper.cn/
> http://www.implight.net/
> http://gro.clinux.org/
> Skyeye-developer mailing list
> Skyeye-developer at lists.gro.clinux.org
> http://lists.gro.clinux.org/cgi-bin/mailman/listinfo/skyeye-developer
