Patch for "strict order mutex"
xi yang
hiyangxi at gmail.com
Thu Oct 18 14:53:21 UTC 2007
1)What's strict order mutex ?
In rtems,when a task release a priority_inheritance or
priority ceiling semaphore,the kernel detect whether
this task holds priority_inheritance or priority
ceiling semaphore, if not, set the priority of task
back to real priority of task.
This method is right, but in theory, we would like
to reset the priority after releasing the mutex if
releasing it in LIFO order.Do it like this can decrease
the blocking time of a higher priority task .
2)How to enable "strict order mutex " ?
When configuring the rtems , add
ENABLE_STRICT_ORDER_MUTEX=1
to your configure parameter.
I add sp36 to test the function of "strict order mutex"
3)About this test program
T0,T1,S0,S1
T0,priority 4
T1,priority 1
S0,priority inheritance
S1,priority ceiling,priority ceiling 2
1,T0 obtain S0 then obtain S1, priority of T0 should be improved to 2
2,T0 try to release S0, but not in strict order, return error code
3,T0 release S1,the priority of T0 back to 4
4,T1 try to obtain S0
5,T1 should be blocked and the priority of T0 should be improved to 1
6,T0 release S0
7,T1 obtain S0
8,OVER.
I test it under bochs , this patch is for rtems that check form CVS as
cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co
-rrtems-4-8-branch rtems
Regards.
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20071018/72ffffc3/attachment.bin>
