Patch for "strict order mutex"
Ray
xr at trasin.net
Fri Oct 19 15:02:17 UTC 2007
Thanks for your work. But pls compress your patch file before send to the maillist.
And I believe that you did not make the right patch in the attachment. It is hard to merge a patch file of 81,000 lines. It is a better idea to make a diff base on a freeze version (e.g. version 4.7.1 or CVS snapshot 4.7.99.2) because CVS is a moving target. It has to keep in mind that the patch should only contain your changes.
Thanks & Best Regards!
Ray
2007-10-19
Date: 2007-10-19 02:15:49
To: RTEMS Users; Joel Sherrill
CC:
Sub: Patch for "strict order mutex"
>1)What's strict order mutex ?
> In rtems,when a task release a priority_inheritance or
> priority ceiling semaphore,the kernel detect whether
> this task holds priority_inheritance or priority
> ceiling semaphore, if not, set the priority of task
> back to real priority of task.
> This method is right, but in theory, we would like
> to reset the priority after releasing the mutex if
> releasing it in LIFO order.Do it like this can decrease
> the blocking time of a higher priority task .
>2)How to enable "strict order mutex " ?
> When configuring the rtems , add
> ENABLE_STRICT_ORDER_MUTEX=1
> to your configure parameter.
>I add sp36 to test the function of "strict order mutex"
>3)About this test program
> T0,T1,S0,S1
> T0,priority 4
> T1,priority 1
> S0,priority inheritance
> S1,priority ceiling,priority ceiling 2
> 1,T0 obtain S0 then obtain S1, priority of T0 should be improved to 2
> 2,T0 try to release S0, but not in strict order, return error code
> 3,T0 release S1,the priority of T0 back to 4
> 4,T1 try to obtain S0
> 5,T1 should be blocked and the priority of T0 should be improved to 1
> 6,T0 release S0
> 7,T1 obtain S0
> 8,OVER.
>I test it under bochs , this patch is for rtems that check form CVS as
>cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co
>-rrtems-4-8-branch rtems
>Regards.
>_______________________________________________
>rtems-users mailing list
>rtems-users at rtems.com
>http://rtems.rtems.org/mailman/listinfo/rtems-users
