Intel 82573L driver
Grigori Khmyrov
Grigori_Khmyrov at uml.edu
Thu Sep 6 15:06:01 UTC 2007
Till,
I've got a problem building the version with driver:
o-optimize/libbsdport/sysbus.o: In function `bus_setup_intr':
/home/khmyrov/DESC/libbsdport/sysbus.c:142: undefined reference to
`bspExtInstallSharedISR'
o-optimize/libbsdport/sysbus.o: In function `bus_teardown_intr':
/home/khmyrov/DESC/libbsdport/sysbus.c:158: undefined reference to
`bspExtRemoveSharedISR'
collect2: ld returned 1 exit status
I'm using RTEMS 4.6.99.3 (i686 BSP). Can you please tell me what I need
to fix it.
Thank you,
Grigori
Grigori Khmyrov wrote:
> Till,
> Can you please send the source code of the driver to me.
> I'd like to test and use it on i386 BSP.
> Thank you,
> Grigori
> Till Straumann wrote:
>> http://www.rtems.com/ml/rtems-users/2007/july/msg00108.html
>>> Hi,
>>> Is anybody can comment on "Intel 82573L Gigabit Ethernet controller"
>>> driver availability.
>>> Thank you,
>>> Grigori
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
