run rtems4.7.99.1 error in skyeye-1.2 .3 on bsp edb7312
invent-lwj
invent-lwj at 163.com
Mon Sep 17 06:59:09 UTC 2007
Hi!
I run rtems4.7.99.1 in skyeye-1.2.3 on bsp edb7312.when i run example "hello","base_sp".it's ok.
but i run example"minimum","unlimited" didn't run.I install linux on vmware.I don't know it's ok whether or not?
In rtems linkcmd,i make some change:
MEMORY {
sdram : ORIGIN = 0xC0000000 , LENGTH = 16M
regs : ORIGIN = 0x80000000, LENGTH = 1M
/* * Declare some sizes. */
_sdram_base = DEFINED(_sdram_base) ? _sdram_base : 0xC0000000 ;
/* *EP7312_INTMR2 = 0x0; */
/* *EP7312_INTMR3 = 0x0; */
[root at localhost minimum]# skyeye -e minimum.exe -c skyeye.conf
big_endian is false.
arch: arm
cpu info: armv4, arm720t, 41807200, ffffff00, 1
mach info: name ep7312, mach_init addr 0x8066880
log_info: log is on.
log_info:log file is /tmp/sk1.log, fd is 0x8714268
log_info: log start clock 2000000
log_info: log end clock 3000000
uart_mod:0, desc_in:, desc_out:, converter:
SKYEYE: use arm7100 mmu ops
exec file "minimum.exe"'s format is elf32-little.
not load section .base: addr = 0xc0000000 size = 0x00000120 .
load section .init: addr = 0xc0000120 size = 0x00000020.
load section .text: addr = 0xc0000140 size = 0x00013cf0.
load section .fini: addr = 0xc0013e30 size = 0x0000001c.
load section .data: addr = 0xc0013e4c size = 0x00000ab0.
load section .eh_frame: addr = 0xc00148fc size = 0x00000004.
load section .rodata: addr = 0xc0014900 size = 0x00000c24.
not load section .bss: addr = 0xc0015540 size = 0x00004ec0 .
not load section .comment: addr = 0x00000000 size = 0x000038c7 .
not load section .debug_aranges: addr = 0x00000000 size = 0x00001fd0 .
not load section .debug_pubnames: addr = 0x00000000 size = 0x00004e00 .
not load section .debug_info: addr = 0x00000000 size = 0x000f7d9f .
not load section .debug_abbrev: addr = 0x00000000 size = 0x0001dca5 .
not load section .debug_line: addr = 0x00000000 size = 0x00027860 .
not load section .debug_frame: addr = 0x00000000 size = 0x00003cf0 .
not load section .debug_str: addr = 0x00000000 size = 0x0000df5c .
not load section .debug_loc: addr = 0x00000000 size = 0x0000fcf3 .
not load section .ARM.attributes: addr = 0x00000000 size = 0x00000010 .
not load section .debug_ranges: addr = 0x00000000 size = 0x00002408 .
start addr is set to 0xc0000140 by exec file.
It stay in there,i wait servel minute.it didn't continue run.please help me!
thanks!
网 易 Yeah.net 邮 箱 夏 日 大 变 脸,带 你 感 受 新 一 代 邮 箱 的 全 新 魅 力 >>
点 击 此 处!免 费 试 玩 07 年 最 受 期 待 的 游 戏 大 作 !
网 易 Yeah.net 免 费 邮 箱 全 新 改 版,珍 藏 帐 号 开 放,快 来 抢 注 >>
URL: <http://lists.rtems.org/pipermail/users/attachments/20070917/f440b4e5/attachment.html>
