run rtems4.7.99.1 error in skyeye-1.2 .3 on bsp edb7312
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Sep 17 13:37:19 UTC 2007
The skyeye.conf I use is:
cpu: arm720t
mach: ep7312
mem_bank: map=I,type=RW, addr=0x80000000, size=0x00100000
mem_bank: map=M, type=RW, addr=0x00000000, size=0x1000000
minimum.exe runs but only has a single task that exits without printing
anything. This results in a fatal error. The purpose of this test is to have
a fully linked application that explicitly doesn't turn anything on. Then
we can see how small a linked executable can be for a particular BSP
and address getting rid of code that you don't expect.
With skyeye SVN checkout from 27 Aug, I could run ticker.exe and
unlimited.exe.
It does not appear that the C++ constructor related stuff in the linkcmds
is correct because the cdtest.exe and iostream.exe tests don't look right.
--joel
invent-lwj wrote:
> Hi!
> I run rtems4.7.99.1 in skyeye-1.2.3 on bsp edb7312.when i run example
> "hello","base_sp".it's ok.
> but i run example"minimum","unlimited" didn't run.I install linux on
> vmware.I don't know it's ok whether or not?
> In rtems linkcmd,i make some change:
> MEMORY {
> sdram : ORIGIN = 0xC0000000 , LENGTH = 16M
> regs : ORIGIN = 0x80000000, LENGTH = 1M
> /* * Declare some sizes. */
> _sdram_base = DEFINED(_sdram_base) ? _sdram_base : 0xC0000000 ;
> /* *EP7312_INTMR2 = 0x0; */
> /* *EP7312_INTMR3 = 0x0; */
> [root at localhost minimum]# skyeye -e minimum.exe -c skyeye.conf
> big_endian is false.
> arch: arm
> cpu info: armv4, arm720t, 41807200, ffffff00, 1
> mach info: name ep7312, mach_init addr 0x8066880
> log_info: log is on.
> log_info:log file is /tmp/sk1.log, fd is 0x8714268
> log_info: log start clock 2000000
> log_info: log end clock 3000000
> uart_mod:0, desc_in:, desc_out:, converter:
> SKYEYE: use arm7100 mmu ops
> exec file "minimum.exe"'s format is elf32-little.
> not load section .base: addr = 0xc0000000 size = 0x00000120 .
> load section .init: addr = 0xc0000120 size = 0x00000020.
> load section .text: addr = 0xc0000140 size = 0x00013cf0.
> load section .fini: addr = 0xc0013e30 size = 0x0000001c.
> load section .data: addr = 0xc0013e4c size = 0x00000ab0.
> load section .eh_frame: addr = 0xc00148fc size = 0x00000004.
> load section .rodata: addr = 0xc0014900 size = 0x00000c24.
> not load section .bss: addr = 0xc0015540 size = 0x00004ec0 .
> not load section .comment: addr = 0x00000000 size = 0x000038c7 .
> not load section .debug_aranges: addr = 0x00000000 size = 0x00001fd0 .
> not load section .debug_pubnames: addr = 0x00000000 size = 0x00004e00 .
> not load section .debug_info: addr = 0x00000000 size = 0x000f7d9f .
> not load section .debug_abbrev: addr = 0x00000000 size = 0x0001dca5 .
> not load section .debug_line: addr = 0x00000000 size = 0x00027860 .
> not load section .debug_frame: addr = 0x00000000 size = 0x00003cf0 .
> not load section .debug_str: addr = 0x00000000 size = 0x0000df5c .
> not load section .debug_loc: addr = 0x00000000 size = 0x0000fcf3 .
> not load section .ARM.attributes: addr = 0x00000000 size = 0x00000010 .
> not load section .debug_ranges: addr = 0x00000000 size = 0x00002408 .
> start addr is set to 0xc0000140 by exec file.
> It stay in there,i wait servel minute.it didn't continue run.please
> help me!
> thanks!
> 网易 Yeah.net 邮 箱 夏 日 大 变 脸,带 你 感 受 新 一 代 邮 箱 的 全
> 新 魅 力 >>
> <http://event.mail.163.com/chanel/click.htm?from=NO_16&domain=163>
> 点击 此 处!免 费 试 玩 07 年 最 受 期 待 的 游 戏 大 作 !
> <http://event.mail.163.com/chanel/click.htm?from=NO_20&domain=163>
> 网易 Yeah.net 免 费 邮 箱 全 新 改 版,珍 藏 帐 号 开 放,快 来 抢 注
> 你玩 过 07 年 最 火 爆 的 网 游 吗 ?还 没 有 ?!点 这 里,点 这 里
> >> <http://event.mail.163.com/chanel/click.htm?from=NO_21&domain=163>
> rtems-users mailing list
> rtems-users at rtems.com
