Undefined reference to DEBUG_puts in RTEMS 4.8
Mon Sep 17 13:29:33 UTC 2007
Daniel Hellstrom wrote:
> Hi,
> Yes, I have seen the DEBUG_puts error and fixed it. It is now part of
> the official CVS too.
Just to make sure that we had completely switched over to printk, I
did a grep from the top. There were a couple of BSPs which still
had it but they were powerpc so understandable that you didn't see them.
But smc91111.h had dbc_printf which used DEBUG_puts. I fixed that
but this left another question. Since smc91111.h
is installed, shouldn't those macros be at the top of the .c file?
> Next release will include a fix for this.
> I haven't tested but I think you could solve the linking problem in the
> meanwhile by declaring DEBUG_puts in you application like:
> void DEBUG_puts(
> char *string
> printk(string);
> or
> void DEBUG_puts(
> char *string
> Thank you for reporting this,
> Daniel Hellstrom
> Aitor.Viana.Sanchez at esa.int wrote:
>> Hi all,
>> i have an error with
>> sparc-rtems-4.7.99.2-gcc-4.2.1-1.0.0-linux.tar.bz2 that I got from
>> Gaisler research. The RTEMS version within this package is 4.8 .
>> I got a piece of SW already compiled and proved with RTEMS 4.6. When I
>> updated to the 4.8 RTEMS version and tried to re-compile the SW I got
>> a linker error:
>> /opt/rtems-4.8/sparc-rtems/leon2/lib/librtemsbsp.a(libnetchip_a-smc91111.o):
>> In function `lan91cxx_interrupt_handler':
>> /home/daniel/reps/rtems48_rep/rtems-4.8-build/sparc-rtems/c/leon2/libchip/../../../../../rtems-4.8/c/src/libchip/network/smc91111.c:121:
>> undefined reference to `DEBUG_puts'
>> The strange thing here is that the path /home/daniel/reps...etc etc
>> does not exist in my machine. I think maybe this is an error of the
>> compiled version I got.
>> any clue?
>> *rtems skyeye <skyeye.rtems at gmail.com>*
>> Sent by: rtems-users-bounces+aitor.viana.sanchez=esa.int at rtems.org
>> 03/09/2007 16:50
>> To
>> 	rtems-users at rtems.org, yanmiaobest at gmail.com
>> cc
>> Subject
>> 	SPAM:**** Fwd: design Real-Time Process in RTEMS
>> hi,
>> Good idea!
>> I think we can first realize the initial VM support in RTEMS.
>> because there are already some page support funcs in rtems X86 port.
>> then we can try syscall,....
>> ---------- Forwarded message ----------
>> From: *阎淼* <_yanmiaobest at gmail.com_ <mailto:yanmiaobest at gmail.com>>
>> Date: Sep 3, 2007 11:21 AM
>> Subject: Re: design Real-Time Process in RTEMS
>> To: rtems skyeye <_skyeye.rtems at gmail.com_
>> <mailto:skyeye.rtems at gmail.com>>
>> Hi:
>> I have been thinking about it too.
>> here is what I think:
>> 1. page routine should be created to support page manipulations(
>> page table operation, TBL, page allocate, set page state ...)
>> 2. identify all system call routines
>> 3. create entry points and exit points for system call
>> 4. adjust context switch ralated routine
>> 5. add privilege transition code
>> best regards!
>> 2007/8/31, rtems skyeye <_skyeye.rtems at gmail.com_
>> <mailto:skyeye.rtems at gmail.com>>:
>>> hi,
>>> VxWorks 6.x have the Real-Time Process (RTP) extension.
>>> I think we also can implement the RTP in RTEMS.
>>> The Idea is :
>>> 1 RTP contains 1~n user-level rtems-task, and process the
>>> virtual memory related things.
>>> 2 the mapping relation of virtual memory :phyiscal memory is 1:1
>>> 3 the user-level task in RTP can access kernel function
>>> by syscall
>>> 4 the user-level tasks and the kernel-level tasks are in the same
>>> scheduling strategy.
>>> the advantage of RTP is:
>>> 1 the crash of user-level tasks in RTP can not destroy user-level
>>> tasks in other RTP and the kernel.
>>> 2 compatible with the old task model.
>>> 3 the context switch is faster than that of general OS (such as linux)
>>> anyone have some advices on RTP in RTEMS?
>>> Regards
>>> skyeye.rtems
>>> rtems-users mailing list
>>> _rtems-users at rtems.com_ <mailto:rtems-users at rtems.com>
>>> _http://rtems.rtems.org/mailman/listinfo/rtems-users_
