design Real-Time Process in RTEMS
rtems skyeye
skyeye.rtems at gmail.com
Mon Sep 17 15:29:02 UTC 2007
hi:
the RTP prototype will be tesed in X86 CPU.
I already let paging (1phy--1 virtual) work correctly. (just use the
Functions already in RTEMS)
I also try the process CPL0--> CPL3 then syscall from CPL3-->CPL0 and
made it work.
Now, I am trying the user-level thread(in CPL3) can cooperate with
kernel-level thread(in CPL0) without paging.
Next, I will try the user-level thread(in CPL3) can cooperate with
kernel-level thread(in CPL0) with 1-1 paging.
I spent my spare time on these works, so the progress is slowly.
Anyone have some advice?
On 9/3/07, rtems skyeye <skyeye.rtems at gmail.com> wrote:
> hi,
> Good idea!
> I think we can first realize the initial VM support in RTEMS.
> because there are already some page support funcs in rtems X86 port.
> then we can try syscall,....
> ---------- Forwarded message ----------
> From: 阎淼 <yanmiaobest at gmail.com>
> Date: Sep 3, 2007 11:21 AM
> Subject: Re: design Real-Time Process in RTEMS
> To: rtems skyeye <skyeye.rtems at gmail.com>
> Hi:
> I have been thinking about it too.
> here is what I think:
> 1. page routine should be created to support page manipulations(
> page table operation, TBL, page allocate, set page state ...)
> 2. identify all system call routines
> 3. create entry points and exit points for system call
> 4. adjust context switch ralated routine
> 5. add privilege transition code
> best regards!
> 2007/8/31, rtems skyeye <skyeye.rtems at gmail.com>:
> > hi,
> > VxWorks 6.x have the Real-Time Process (RTP) extension.
> > I think we also can implement the RTP in RTEMS.
> > The Idea is :
> > 1 RTP contains 1~n user-level rtems-task, and process the
> > virtual memory related things.
> > 2 the mapping relation of virtual memory :phyiscal memory is 1:1
> > 3 the user-level task in RTP can access kernel function
> > by syscall
> > 4 the user-level tasks and the kernel-level tasks are in the same
> > scheduling strategy.
> > the advantage of RTP is:
> > 1 the crash of user-level tasks in RTP can not destroy user-level
> > tasks in other RTP and the kernel.
> > 2 compatible with the old task model.
> > 3 the context switch is faster than that of general OS (such as
> linux)
> > anyone have some advices on RTP in RTEMS?
> > Regards
> > skyeye.rtems
> > rtems-users mailing list
> > rtems-users at rtems.com
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20070917/02352129/attachment.html>
