[PATCH] network demo "http" for 4.7.99.2 would not compile
Torsten Landschoff torsten.landschoff at nambition.com
Mon Sep 17 14:37:39 UTC 2007
Hi list,
Compiling the network demos failed here with the following error message:
powerpc-rtems4.8-objcopy -I binary -O `cat obj_format` tarfile
o-optimize/tarfile.o
powerpc-rtems4.8-gcc --pipe
-B/home/torsten/opt/powerpc-rtems4.8/powerpc-rtems4.8/virtex/lib/ -specs
bsp_specs -qrtems   -g -Wall  -O2 -g -fno-keep-inline-functions -g
-DUSE_FTPD -isystem
/home/torsten/tes-board/fpga_rev_05/FPGA_MST/PPC_SYSTEM/ppc405_0/include
-mcpu=403 -Dppc405 -Dvirtex         -o o-optimize/http.exe
o-optimize/init.o   o-optimize/tarfile.o  -lftpd
/home/torsten/opt/powerpc-rtems4.8/lib/gcc/powerpc-rtems4.8/4.2.1/../../../../powerpc-rtems4.8/bin/ld:
unknown architecture of input file `o-optimize/tarfile.o' is
incompatible with powerpc:common output
collect2: ld returned 1 exit status
The following patch fixes this for my configuration (powerpc4.8-rtems
with virtex BSP). I am not entirely sure if this is the correct way to
fix this, perhaps somebody has a better proposal.
diff --git a/http/Makefile b/http/Makefile
index c211e78..17737ff 100644
--- a/http/Makefile
+++ b/http/Makefile
@@ -88,7 +88,7 @@ ${PGM}: $(OBJS) $(LINK_FILES)
 $(ARCH)/tarfile.o: $(ARCH) stamp-index-html obj_format
        cd rootfs ; tar cf ../$(ARCH)/tarfile --exclude CVS .
        cp $(ARCH)/tarfile .
-       $(OBJCOPY) -I binary -O `cat obj_format` tarfile $(ARCH)/tarfile.o
+       $(OBJCOPY) --binary-architecture=$(RTEMS_CPU) -I binary -O `cat
 stamp-index-html: index.html.in
 ifneq ($(HTTPD),)
Greetings, Torsten
