3c905 Nic configuration
Karel Gardas
kgardas at objectsecurity.com
Tue Sep 25 16:43:18 UTC 2007
Hello,
IIRC 3c905x is different from 3c509. Please use xl driver for your card
and it should work well.
Cheers,
Karel
Stéphane ARQUER wrote:
> Hello,
> I'm trying to configure the network interface 3c905c-TXM with the pc386
> bsp of rtems 4.6.6.
> I read in the wiki that someone used this reference in september 2005 but
> there is no details on the driver to use.
> On the other hand, I'm working with a 3c509B-tpo card, I try to execute
> the network examples and when the card seems to be configured:
> --> 3C509: attach() is complete
> there are the error messages:
> --> Can't bring ep up: No such device or adress
> --> Can't set default route: No such process
> --> Can't get host adress
> You 'll find attached the networkconfig.h file.
> If anyone has a tip ?
> Thanks in advance for your help.
> Regards.
> SA
> rtems-users mailing list
> rtems-users at rtems.com
Karel Gardas kgardas at objectsecurity.com
ObjectSecurity Ltd. http://www.objectsecurity.com
