3c905 Nic configuration
Stéphane ARQUER
stephane.arquer at c-s.fr
Tue Sep 25 16:58:29 UTC 2007
Hello,
I'm trying to configure the network interface 3c905c-TXM with the pc386
bsp of rtems 4.6.6.
I read in the wiki that someone used this reference in september 2005 but
there is no details on the driver to use.
On the other hand, I'm working with a 3c509B-tpo card, I try to execute
the network examples and when the card seems to be configured:
--> 3C509: attach() is complete
there are the error messages:
--> Can't bring ep up: No such device or adress
--> Can't set default route: No such process
--> Can't get host adress
You 'll find attached the networkconfig.h file.
If anyone has a tip ?
Thanks in advance for your help.
Regards.
SA
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20070925/609bdcba/attachment-0001.obj>
