4.8 examples
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Sep 10 14:55:36 UTC 2007
Jiri Gaisler wrote:
> I think you also need to include the timer manager. This should
> be fixed in the bsp, rather then by changing the tests. I will
> look into it ...
The tests can't generically assume a lot about what the BSP needs.
In general, the tests are better off saying "all" since with 100 BSPs,
you might not have the same requirements across all BSPs. For
a user application, you should have a small enough BSP set that
you can make a better statement about what is really required.
For size purpose, MANAGERS=all is often better anyway.
--joel
> Jiri.
> Joel Sherrill wrote:
>> Jerry Needell wrote:
>>> Joel,
>>> I finally got around to downloading and building the CVS head
>>> for the leon3 and everything went well until I downloaded and ran
>>> some of the examples from the examples tree. They would build fine,
>>> but when I ran them on a LEON3 (in tsim or hardware) they would fail
>>> on an Internal error. I downloaded the class_examples tree and they
>>> worked fine. In looking at the differences in the Makefiels, I found
>>> that in the example tree, in hello_world_c, the Makefile only
>>> include the io Manager. In the class_examples it include "all"
>>> managers. I changed the Makefile to include all Mamagers and the
>>> hello_world_c example ran successfully under tsim.
>>> So, it looks like the examples tree needs to be updated, and this
>>> also raises the question, what Managers are required for the
>>> hello_world_c example?
>> You definitely have to have IO since it is using the console
>> driver. If the console driver is using termios, it also needs
>> the Classic API semaphore manager.
>> In 4.7, the Classic API semaphore manager was required in
>> all applications. Now it is optional. So is the region manager.
>> Making this change resulted in a number of cases where the
>> optional managers line was wrong. I have fixed the examples
>> in CVS.
>> Thanks for testing this.
>> --joel
>>> Best regards,
>>> Jerry
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
