How to build tests under testsuites/sptests?
Ian Jiang
ianjiang.cn at gmail.com
Wed Sep 19 06:50:21 UTC 2007
That is right! All tests could be found under
/home/ian/rtems/b-rtems/arm-rtems4.7/c/edb7312/testsuites/
The reason of my previous failure might be that I did start configuration and making from a clean directory.
Thanks a lot!
>Ian Jiang wrote:
>> I am using Suse-10.2 and the rtems developing tools was built from source RPMS from
>> http://www.rtems.com/ftp/pub/rtems/linux/4.7/suse/10.2/SRPMS/
>> Now I want to build tests under testsuites/sptests. The following configuration is used:
>> ian at IanVM-1:~/rtems/b-rtems> ../../src/rtems-4.7.1/configure --target=arm-rtems4.7 --enable-posix --enable-cxx --enable-rtemsbsp=edb7312 --enable-tests --prefix=/home/ian/rtems/rtemsdocs-4.7.1
>> But I have got only samples after "make all".
>They are just scattered in the build directory. Try
>find /home/ian/rtems/b-rtems/ -name "*.exe"
>they should be there.
>> Any suggestion is appreciated!
>> Best wishes!
>> Ian Jiang
>> 2007-09-18 16:48:07
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
