RTEMS vs. changing hardware: Building app against RTEMS build tree?
Thomas Doerfler
Thomas.Doerfler at embedded-brains.de
Sat Sep 22 16:50:36 UTC 2007
Hi,
this should work, although I did not yet try it out.
The big thing to change should be that the environment variable pointing
to the installed system should be changed from something like
RTEMS_MAKEFILE_PATH=/opt/rtems-4.8/powerpc-rtems4.8/virtex
to
RTEMS_MAKEFILE_PATH=b-rtems/rtems-4.8/powerpc-rtems4.8/virtex
what you are missing then are "Makefile.inc", "make/bsp.cfg" and
"make/target.cfg". But there should be a way to come over this.
If you have a working solution, this would be nice to see in the RTEMS wiki
wkr,
Thomas.
Torsten Landschoff schrieb:
> Hi List,
> We are adapting RTEMS here to run our embedded control application on a
> Virtex4 FPGA (or rather the integrated PowerPC core).
> I am searching for relief from the "make all install" burden, which is
> probably not neccessary anyway: Whenever I reconfigure the FPGA, I am
> doing a rebuild of RTEMS and doing a make install.
> However, for our application I would like to have a combined tree.
> Currently, it is organized roughly as follows:
> working-copy
> + edk_repository (contains pcores and board definitions)
> + fpga_system (Xilinx XPS project with the hardware configuration)
> + rtems (contains the RTEMS source, currently 4.7.99.2)
> + b-rtems (build tree of RTEMS)
> + controller (contains the controller application, built against RTEMS)
> After building RTEMS into b-rtems, I'll do a "make install", which
> stores the whole thing into the prefix $HOME/opt/powerpc-rtems4.8. I
> figure that I can just install it into a local directory rtems-install
> but I'd rather just directly link against the build tree (which
> obviously works for the testsuite).
> Before I delve into the Makefile sources: Does somebody here already use
> a similar setup?
> Thanks and Greetings, Torsten
> rtems-users mailing list
> rtems-users at rtems.com
Embedded Brains GmbH
Thomas Doerfler Obere Lagerstr. 30
D-82178 Puchheim Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax: +49-89-18908079-9
