NASA Dawn Mission
Jiri Gaisler jiri at gaisler.com
Wed Sep 26 14:14:29 UTC 2007
You probably mean the Dawn Framing Camera (FC). It is controlled
by a LEON2 cpu in a Xilinx FPGA, running RTEMS. Some links
are here, I am sure can google up some more ...
http://portal.acm.org/ft_gateway.cfm?id=1266578&type=pdf&coll=ACM&dl=ACM&CFID=15151515&CFTOKEN=6184618
http://www.cosis.net/abstracts/EGU2007/09388/EGU2007-J-09388.pdf
Jiri.
PS. An interesting question would be who has the most
lines of code in the system. The LEON2 cpu is about
50,000 lines (of VHDL) - how much is RTEMS ...?   :-)
Joel Sherrill wrote:
> Hi,
> Today's Huntsville Times had an article on the
> Dawn mission since it is managed here at Marshall
> and should launch soon.
> It mentioned instrumentation Germany.  Is
> some of this running RTEMS?  It all sound
> familiar like it is something I know about.
> I will post the link once it is available online
> if someone can confirm some RTEMS on this mission. :D
> --joel
> rtems-users mailing list
> rtems-users at rtems.com
