NASA Dawn Mission
Wed Sep 26 15:21:09 UTC 2007
Jiri Gaisler wrote:
> You probably mean the Dawn Framing Camera (FC). It is controlled
> by a LEON2 cpu in a Xilinx FPGA, running RTEMS. Some links
> are here, I am sure can google up some more ...
> http://portal.acm.org/ft_gateway.cfm?id=1266578&type=pdf&coll=ACM&dl=ACM&CFID=15151515&CFTOKEN=6184618
> http://www.cosis.net/abstracts/EGU2007/09388/EGU2007-J-09388.pdf
So this camera is an instrument on this mission?
http://dawn.jpl.nasa.gov/
Which launches tomorrow about 7:20am EDT. :-D
We get the Nasa channel on our local cable systems
so I will have to watch for sure if it is running RTEMS.
> Jiri.
> PS. An interesting question would be who has the most
> lines of code in the system. The LEON2 cpu is about
> 50,000 lines (of VHDL) - how much is RTEMS ...?   :-)
I don't know how you got that number for the LEON2 but
cpukit has 307K if you wc -l the .c, .h and .inl files.  There
are 92K in  rtems, score, and libcsupport.
But they are using all of the LEON2 VHDL and probably
not running TCP/IP or the POSIX API. It might actually be
close.
--joel
> Joel Sherrill wrote:
>> Hi,
>> Today's Huntsville Times had an article on the
>> Dawn mission since it is managed here at Marshall
>> and should launch soon.
>> It mentioned instrumentation Germany.  Is
>> some of this running RTEMS?  It all sound
>> familiar like it is something I know about.
>> I will post the link once it is available online
>> if someone can confirm some RTEMS on this mission. :D
>> --joel
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
