--wrap ld functionality does not work with Init RTEMS function
Tue Apr 8 21:41:46 UTC 2008
Aitor Viana wrote:
> Hi,
>> Hi,
>> Joel, your example is a bit off-topic (sorry for that), because it
>> wraps a function that is outside the local module.
>> Have a look at my modified example.
>> There I have a local function (my_malloc) which is referenced by a
>> global, constant pointer and which should be wrapped. But the
>> wrapper will not be called.
>> This is similar to the Init module problem.
>> I guess that the compiler already processes the link between the
>> (const?) pointer and the local function, and therefore the linker is
>> no longer able to interfer.
>> sigh,
>> Thomas
> touche. Can anybody figure out the workaround?
First we have to trip the problem in a simple native way.
Then we report it to (probably) binutils.
If it does turn out to be indirection through a table
via a function in another module, the workaround
is most likely to (unfortunately) change the user's
configuration table to call the wrapper directly.
We need a small test case native that breaks.  Then we
track it down.
