Virtex BSP and configure questions
Robert S. Grimes rsg at alum.mit.edu
Fri Apr 11 17:14:48 UTC 2008
Thomas Doerfler wrote:
> as far as I reconstruct, the proper addition to configure is:
> ../rtems/configure --target=powerpc-rtems4.8 .... \
> RTEMS_XPARAMETERS_H=/my/path/to/the/edk/generated/file/x_parameters.h
Thanks, I'll give it a go.
>>   2. Given that I've already built RTEMS, how can I determine what
>>      options were used for configure?
> in your build-directory (which you hopefully did not delete), you will
> find the "config.status" and "config.log" files. Both contain a copy of
> the configure command line you entered.
I figured it would be something real simple like that!
BTW - Interrupts now work just fine, as does my SPI and FRAM drivers.
At some point, I would be happy to contribute the Virtex/SPI driver, but
it's a little sloppy right now, and I can't figure out the automake
stuff - no time with my project schedule, mainly.  I'd also like to use
it more before I stand behind it, but if anyone actually wants to use
it, warts and all, I can accommodate that...
Take care, and thanks as always!
-Bob
