Virtex BSP and configure questions
Arnout Vandecappelle arnout at mind.be
Fri Apr 11 22:55:30 UTC 2008
Robert S. Grimes wrote:
> Thomas Doerfler wrote:
>> in your build-directory (which you hopefully did not delete), you will
>> find the "config.status" and "config.log" files. Both contain a copy of
>> the configure command line you entered.
> I figured it would be something real simple like that!
 It's even simpler: type `./config.status --version' and it will print
your configure command line.
 Regards,
 Arnout
Arnout Vandecappelle                     arnout at mind be
Senior Embedded Software Architect       +32-16-286540
Mind Embedded Development (an Essensium division)
