can not transmit udp packet
朱旭峰
fall4ufeng at gmail.com
Tue Apr 15 13:22:27 UTC 2008
hi, all:
i am using netdemo example to develop a rhine netcard rtems
driver.
the sniffer can catch tcp packet when i test tcp transmitting,
but when i test udp transmitting the console give
me the folloing information:
RTEMS:Can't send , No buffer space availble.
i used gdb to find what happend, and i found the function called
order is
transmitUd -> sendto -> sendmsg -> rtems_bsdnet_fdToSocket
the program run into
if(( iop -> flags & LIBIO_FLAGS_OPEN) == 0 )
errno = EBADF;
return NULL;
in the rtems_bsdnet_fdToSocket function , and the iop -> flags
here is 0, so the error happened.
According to this, can anyone give me some advices?
Thanks a lot.
URL: <http://lists.rtems.org/pipermail/users/attachments/20080415/26d33914/attachment.html>
