rtems-cvs toolchain
Nigel Spon nigel at adi.co.nz
Tue Apr 22 03:36:05 UTC 2008
On 22/04/2008, at 11:00 AM, Joel Sherrill wrote:
> It would be nice to get a 405 BSP back in the tree but that
> one was using (God help me) .. the other exception model
> and was the last one.  So it was removed in the interest
> of forward motion.
Hmm. Forward motion is good, but I seem to have gone too far forward
and wound up in a bog.
After a lot of updating and unpacking, I find I can't compile gcc
4.3.0 because it needs mpfr and gmp. I have the latest versions of
these (2.3.1 and 4.2.2) and they build, but they default to 64-bit (-
m64 -mtune=k8). The gcc build doesn't like this:
configure:4543: checking for correct version of mpfr.h
configure:4574: /Developer/usr/bin/cc -o conftest -g -O2
conftest.c  -lmpfr -lgmp >&5
ld: warning in /usr/local/lib/libmpfr.dylib, file is not of required
architecture
ld: warning in /usr/local/lib/libgmp.dylib, file is not of required
architecture
If I try building gmp with ABI=32 the build fails with a lot of:
fib_table.c:61: warning: integer constant is too large for 'long' type
A bit of Googling reveals that Apples gcc is not popular with the gmp/
mpfr folks because Apple do bad things, etc, etc, so it doesn't look
hopeful.
I don't think I'm going to be able to do anything with RTEMS 4.9. I
may have to do what I can with RTEMS 4.8.
“Now, the objective of this expedition is to attempt to find some
trace of last years expedition.”
Michael Hamel
ADInstruments Ltd, Dunedin, NZ
