rtems-cvs toolchain
Mon Apr 21 23:00:47 UTC 2008
Nigel Spon wrote:
> I have been working with RTEMS 4.8 and have managed to get some code
> running on my 405EX hardware based on the obsolete gen405 BSP. This is
> clearly not the way to go, however, so I presume I should be working
> with the rtems-cvs code and the new bsp exception support. What
> toolchain do I need to compile the cvs code?
When you check out CVS, there is a contrib/crossrpm
directory with a patches subdirectory.  That is where
the RPM specs are generated and (one place) where
the patches are.
Just grab the newest patches and tool versions and build
those targeting 4.9.
It would be nice to get a 405 BSP back in the tree but that
one was using (God help me) .. the other exception model
and was the last one.  So it was removed in the interest
of forward motion.
> Will the 4.8 tools do?
No.
> "As your attorney I advise you to get the chiliburger."
> Michael Hamel
> ADInstruments Ltd, Dunedin, NZ
> rtems-users mailing list
> rtems-users at rtems.com
