Leon2 RAM configuration
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Wed Apr 23 13:43:08 UTC 2008
Hello,
Arquer Stephane schrieb:
> Hello,
> This is not the same behaviour with rtems 4.7.1, the RAM size is correctly found.
> Is there something different in the boot between these version  ?
At least the CVS says, that there is no substantial difference in the
file "start.S".
Since I don't have a LEON target here, I really can't tell you more ATM,
sorry.
wkr,
Thomas.
> Thanks.
> sa
>> -----Message d'origine-----
>> De : Thomas Doerfler [mailto:Thomas.Doerfler at imd-systems.de]
>> Envoyé : mercredi 16 avril 2008 13:16
>> À : Arquer Stephane
>> Cc : rtems-users at rtems.com
>> Objet : Re: Leon2 RAM configuration
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Hi,
>> if I remember right, the LEON BSP startup function assumes,
>> that the stack pointer points to top of the usable RAM when
>> it is called from the boot monitor.
>> It should be worth a try :-)
> What do you mean ?
>> wkr,
>> Thomas.
>> | Hi,
>> | I work with rtems 4.8.0 and bsp leon2.
>> | I use Redboot to load rtems application on the target.
>> | When I load a bin file with Redboot, I don't have all the
>> SRAM size =
>> | 8 MB available. Otherwise, when I load the same application with
>> | GRMON, there is no problem.
>> | MCFG2 register is configured with the correct amount of SRAM:
>> | 0xB0801460
>> | Does anyone knows if there is another leon2 register used by Rtems
>> | during the initialization to calculate the heap space ?
> rtems-users mailing list
embedded brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
Tel. : +49-89-18 90 80 79-2
Fax  : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
