Leon2 RAM configuration
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Apr 23 13:57:18 UTC 2008
Thomas Doerfler wrote:
> Hello,
> Arquer Stephane schrieb:
>> Hello,
>> This is not the same behaviour with rtems 4.7.1, the RAM size is correctly found.
>> Is there something different in the boot between these version ?
> At least the CVS says, that there is no substantial difference in the
> file "start.S".
There are some differences in the file libbsp/sparc/shared/bspstart.c.
Hard to tell if they matter. It looks mostly cosmetic except for the
cache snooping setup.
I attached the diff.
> Since I don't have a LEON target here, I really can't tell you more ATM,
> sorry.
> wkr,
> Thomas.
>> Thanks.
>> sa
>>> -----Message d'origine-----
>>> De : Thomas Doerfler [mailto:Thomas.Doerfler at imd-systems.de]
>>> Envoyé : mercredi 16 avril 2008 13:16
>>> À : Arquer Stephane
>>> Cc : rtems-users at rtems.com
>>> Objet : Re: Leon2 RAM configuration
>>> -----BEGIN PGP SIGNED MESSAGE-----
>>> Hash: SHA1
>>> Hi,
>>> if I remember right, the LEON BSP startup function assumes,
>>> that the stack pointer points to top of the usable RAM when
>>> it is called from the boot monitor.
>>> It should be worth a try :-)
>> What do you mean ?
>>> wkr,
>>> Thomas.
>>> | Hi,
>>> | I work with rtems 4.8.0 and bsp leon2.
>>> | I use Redboot to load rtems application on the target.
>>> | When I load a bin file with Redboot, I don't have all the
>>> SRAM size =
>>> | 8 MB available. Otherwise, when I load the same application with
>>> | GRMON, there is no problem.
>>> | MCFG2 register is configured with the correct amount of SRAM:
>>> | 0xB0801460
>>> | Does anyone knows if there is another leon2 register used by Rtems
>>> | during the initialization to calculate the heap space ?
>> rtems-users mailing list
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
> embedded brains GmbH
> Thomas Doerfler Obere Lagerstr. 30
> D-82178 Puchheim Germany
> Tel. : +49-89-18 90 80 79-2
> Fax : +49-89-18 90 80 79-9
> email: Thomas.Doerfler at embedded-brains.de
> PGP public key available on request
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20080423/bc3491e9/attachment.bin>
