BSP for 405EX
Nigel Spon nigel at adi.co.nz
Wed Apr 30 23:30:56 UTC 2008
On 29/03/2008, at 1:36 PM, Till Straumann wrote:
> I'd like to add my 2 cents here; recently a framework for supporting
> exceptions
> and interrupts has been added under
> libcpu/powerpc/new-exceptions/bspsupport
> please consider using that framework rather than deriving your own
> variants
> from
> libbsp/powerpc/shared/irq/irq_asm.S
> libbsp/powerpc/shared/vectors/vectors.S
> libbsp/powerpc/virtex/irq_init.c
> etc.
I have made a start on BSP for the 405GP/405EX which uses the
bspsupport code, and it is basically working. However, it looks as
though I may be losing interrupts and I suspect I have not implemented
BSP_enable_irq_at_pic or C_dispatch_irq_handler correctly.
My question is, should I be expecting BSP_disable_irq_at_pic to be
potentially called from within the interrupt handlers called by
bsp_irq_dispatch_list? If so, the implementation of
BSP_disable_irq_at_pic can't just write to the PIC hardware, because
the PIC hardware has to be used to inhibit any level-sensitive
interrupts from recurring the moment bsp_irq_dispatch_list re-enables
interrupts - because the interrupt handlers haven't cleared the source
yet. The exact sequence of events at this point then gets a bit
tricky...
Thanks,
" The boy stood on the burning deck, whence all but he had fled!
Twit."
Michael Hamel
ADInstruments Ltd, Dunedin, NZ
