Error building gcc 4.2.1 for sparc target?
Thu Apr 3 13:30:13 UTC 2008
mike wrote:
> Never mind. Found it. It was an older version of 'as'. Building
> a newer version of binutils 2.17 for host fixed it.
Something else changed in your environment.
You are getting invalid instruction errors from the assembler.
It looks like as in your path is NOT the native one.  push is
a native x86 instruction not a SPARC one.
But the bigger issue is Ralf's point.. why not use the RPMs?
We have an apt/yum repository and it would have taken
less time to install them that write the two emails.
--joel
> mike wrote:
>> Hi all,
>> My host: Linux Redhat. Host tools: gcc 4.1.1
>> Target : sparc-rtems
>> I followed the documentation to build binutils 2.17 without any problem.
>> When I tried to build gcc 4.2.1 (same errors for 4.1.1) for
>> 'sparc-rtems' target following the doc,
>> I got the following errors during "make all". I would really appreciate
>> any pointers.
>> Thank you.
>> -mike-
>>         gcc -c   -g -O2 -DIN_GCC -DCROSS_COMPILE  -W -Wall
>> -Wwrite-strings -Wstrict-prototypes -Wmissing-prototypes
>> -Wold-style-definition -Wmissing-format-attribute    -DHAVE_CONFIG_H -I.
>> -I. -I../../gcc-4.2.1/gcc -I../../gcc-4.2.1/gcc/.
>> -I../../gcc-4.2.1/gcc/../include
>> -I../../gcc-4.2.1/gcc/../libcpp/include
>> -I../../gcc-4.2.1/gcc/../libdecnumber -I../libdecnumber
>> -DSTANDARD_STARTFILE_PREFIX=\"../../../\"
>> -DSTANDARD_EXEC_PREFIX=\"/opt/rtems-4.8.0-tools/lib/gcc/\"
>> -DSTANDARD_LIBEXEC_PREFIX=\"/opt/rtems-4.8.0-tools/libexec/gcc/\"
>> -DDEFAULT_TARGET_VERSION=\"4.2.1\"
>> -DDEFAULT_TARGET_MACHINE=\"sparc-rtems\"
>> -DSTANDARD_BINDIR_PREFIX=\"/opt/rtems-4.8.0-tools/bin/\"
>> -DTOOLDIR_BASE_PREFIX=\"../../../../\"  `test "X${SHLIB_LINK}" = "X" ||
>> test "yes" != "yes" || echo "-DENABLE_SHARED_LIBGCC"` `test
>> "X${SHLIB_MULTILIB}" = "X" || echo "-DNO_SHARED_LIBGCC_MULTILIB"` \
>>                 -I. -I. -I../../gcc-4.2.1/gcc -I../../gcc-4.2.1/gcc/.
>> ../../gcc-4.2.1/gcc/cp/g++spec.c)
>> /tmp/ccVxeQoU.s: Assembler messages:
>> /tmp/ccVxeQoU.s:17: Error: Unknown opcode: `pushl'
>> /tmp/ccVxeQoU.s:19: Error: Illegal operands
>> /tmp/ccVxeQoU.s:22: Error: Unknown opcode: `xorl'
>> /tmp/ccVxeQoU.s:23: Error: Unknown opcode: `leave'
>> /tmp/ccVxeQoU.s:137: Error: Unknown opcode: `pushl'
>> /tmp/ccVxeQoU.s:139: Error: Illegal operands
>> /tmp/ccVxeQoU.s:141: Error: Unknown opcode: `pushl'
>> /tmp/ccVxeQoU.s:143: Error: Unknown opcode: `pushl'
>> /tmp/ccVxeQoU.s:145: Error: Unknown opcode: `pushl'
>> /tmp/ccVxeQoU.s:147: Error: Unknown opcode: `subl'
>> /tmp/ccVxeQoU.s:149: Error: Illegal operands
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
