what exception model should I use ?
阎淼
yanmiaobest at gmail.com
Sun Apr 6 12:01:33 UTC 2008
Hi,
I am using rtems4.8, and the README file is allocated at
c/src/lib/libcpu/powerpc, some of the contents:
At this time, support is included for the following PowerPC
family members using the new exception processing model:
+ mpc505
+ mpc5xx (5xx devices other than 505/509)
+ mpc6xx
+ mpc750
+ mpc821
+ mpc823 (uses mpc821 directory)
+ mpc850 (uses mpc860 directory)
+ mpc860
+ mpc8260
The following PowerPC family members are supported but
still use the old exception processing model:
+ ppc403
+ ppc405 (uses ppc403 directory)
+ ppc6xx (no libcpu support)
so I thought ppc603e is supported by old exception processing model.
and If I use new exception processing, I should just use code under
c/src/lib/libcpu/powerpc/new-exception, right?
do I need to define any special macros ?
2008/4/6, Thomas Doerfler (nt) <Thomas.Doerfler at imd-systems.de>:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi,
> this is simple, use the new one, because the "old" is no longer supported.
> which README did you consult? which RTEMS version are you using?
> wkr,
> Thomas.
> 阎淼 schrieb:
> | Hi,
> | I have a ppc603e based borad, which exception model should I use,
> | new or old?( I think it should be old exception model accroding to the
> | README file).
> | and what macro should I define to chose between the two? and where
> | can I find the clock driver support, is it similar to ppc403?
> | _______________________________________________
> | rtems-users mailing list
> | rtems-users at rtems.com
> | http://rtems.rtems.org/mailman/listinfo/rtems-users
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler Herbststrasse 8
> D-82178 Puchheim Germany
> email: Thomas.Doerfler at imd-systems.de
> PGP public key available at:
> ~ http://www.imd-systems.de/pgpkey_en.html
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.2.5 (MingW32)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFH+J4owHyg4bDtfjQRAgEAAKCW2YM4nO26Ni+IGpmfBOWC485jGQCfdXg1
> lnxmKvqlpix0ZZZphTdpBAc=
> =xjBu
> -----END PGP SIGNATURE-----
