what exception model should I use ?
Thomas Doerfler
Thomas.Doerfler at embedded-brains.de
Mon Apr 7 07:49:21 UTC 2008
Hi,
the information in the README is no longer correct (at least for
CVS-HEAD). I will fix this ASAP.
Nevertheless, the 603e is covered in the mpc6xx stuff (e.g. in the
mpc52xx and the mpc83xx), so you should be able to use the new exception
handling anyway.
If you would use the old exception handling stuff, your port would not
be compatible with any upcoming version of RTEMS.
wkr,
Thomas.
阎淼 schrieb:
> Hi,
> I am using rtems4.8, and the README file is allocated at
> c/src/lib/libcpu/powerpc, some of the contents:
> At this time, support is included for the following PowerPC
> family members using the new exception processing model:
> + mpc505
> + mpc5xx (5xx devices other than 505/509)
> + mpc6xx
> + mpc750
> + mpc821
> + mpc823 (uses mpc821 directory)
> + mpc850 (uses mpc860 directory)
> + mpc860
> + mpc8260
> The following PowerPC family members are supported but
> still use the old exception processing model:
> + ppc403
> + ppc405 (uses ppc403 directory)
> + ppc6xx (no libcpu support)
> so I thought ppc603e is supported by old exception processing model.
> and If I use new exception processing, I should just use code under
> c/src/lib/libcpu/powerpc/new-exception, right?
> do I need to define any special macros ?
> 2008/4/6, Thomas Doerfler (nt) <Thomas.Doerfler at imd-systems.de>:
> Hi,
> this is simple, use the new one, because the "old" is no longer supported.
> which README did you consult? which RTEMS version are you using?
> wkr,
> Thomas.
> ü schrieb:
> | Hi,
> | I have a ppc603e based borad, which exception model should I use,
> | new or old?( I think it should be old exception model accroding to the
> | README file).
> | and what macro should I define to chose between the two? and where
> | can I find the clock driver support, is it similar to ppc403?
> | _______________________________________________
> | rtems-users mailing list
> | rtems-users at rtems.com
> | http://rtems.rtems.org/mailman/listinfo/rtems-users
embedded brains GmbH
Thomas Doerfler Obere Lagerstr. 30
D-82178 Puchheim Germany
Tel. : +49-89-18 90 80 79-2
Fax : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
Diese Nachricht ist keine gescha"ftliche Mitteilung im Sinne des EHUG.
