More build oddities
Ralf Corsepius ralf.corsepius at rtems.org
Mon Apr 7 08:39:51 UTC 2008
On Mon, 2008-04-07 at 16:32 +1000, Angelo Fraietta wrote:
> Nigel Spon wrote:
> > I'm trying to use scripts to build RTEMS under MacOS X, but I'm having
> > persistent difficulties with the PATH variable. I may be being over-
> > optimistic, but I thought I could avoid the nasty detail of having to
> > put the path to the RTEMS tools into my global .tcshrc file, by
> > invoking make from a script, like this:
> I originally had trouble with OSX, however, there is a tutorial (2 years
> old) that worked for OSX
> http://thesis.smartcontroller.com.au/rtems/RTEMSForSmartController.html
> In teh tutu is says
> On Mac OS X (Darwin) you'll have to use the command:
> make -w "CC=cc -no-cpp-precomp" all install
> Let me know how you go
Pardon, but what you write above would indicate that OSX's gcc would be
completely bugged.
Ralf
