More build oddities
Angelo Fraietta newsgroups at smartcontroller.com.au
Tue Apr 8 02:19:45 UTC 2008
Ralf Corsepius wrote:
> On Mon, 2008-04-07 at 16:32 +1000, Angelo Fraietta wrote:
>>Nigel Spon wrote:
>>>I'm trying to use scripts to build RTEMS under MacOS X, but I'm having
>>>persistent difficulties with the PATH variable. I may be being over-
>>>optimistic, but I thought I could avoid the nasty detail of having to
>>>put the path to the RTEMS tools into my global .tcshrc file, by
>>>invoking make from a script, like this:
>>I originally had trouble with OSX, however, there is a tutorial (2 years
>>old) that worked for OSX
>>http://thesis.smartcontroller.com.au/rtems/RTEMSForSmartController.html
>>In teh tutu is says
>>On Mac OS X (Darwin) you'll have to use the command:
>>make -w "CC=cc -no-cpp-precomp" all install
>>Let me know how you go
> Pardon, but what you write above would indicate that OSX's gcc would be
> completely bugged.
> Ralf
That may very well be true - I don't know because that is not my area of
expertise. I was unable to make OSX work until Eric Norum showed me that.
Dr Angelo Fraietta
A.Eng, A.Mus.A, BA(Hons), Ph.D.
PO Box 859
Hamilton NSW 2303
Home Page
http://www.smartcontroller.com.au/
There are those who seek knowledge for the sake of knowledge - that is
CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
     Bernard of Clairvaux (1090 - 1153)
