--wrap ld functionality does not work with Init RTEMS function
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Apr 8 19:12:52 UTC 2008
Aitor Viana wrote:
> Hi all,
> On Tue, Apr 8, 2008 at 7:38 PM, Thomas Dörfler
> <Thomas.Doerfler at embedded-brains.de
> <mailto:Thomas.Doerfler at embedded-brains.de>> wrote:
> Hi,
> Joel Sherrill schrieb:
> > Aitor.Viana.Sanchez at esa.int <mailto:Aitor.Viana.Sanchez at esa.int>
> wrote:
> >> Hi all,
> >> does anybody knows why when trying to wrap the Init RTEMS function
> >> with the ld --wrap functionality everything compiles well but
> >> eventually the wrapper function is not executed?
> >> Maybe I am missing something, but is taking me a while to
> discover why.
> > Init is a task/thread and threads will not return to the wrapper.
> > They are entered but exit via rtems_task_delete or pthread_exit.
> > I would expect the wrapper to be entered, then Init but no return
> > from Init.
> Normally Init will be referenced from within the same module: The
> "init.c" module contains the first task AND the default list in init
> tasks (somehwere deep down in system.h -> confdefs.h). And therefore I
> would expect that the pointer in the list of init tasks will point to
> the REAL function, no matter how it might have been renamed.
> Does this make sense?
> yes, I think this is the problem, the indirect point. Because when
> trying to wrap the Init function, the wrapper function (__wrap_Init())
> is never called, maybe because it is called from an indirect pointer.
> I will try to dig deeply...but I would really need to wrap the Init
> function (task, thread, whatever).
My example worked with an indirect function pointer.
Can you look at the Initialization_tasks[] structure contents on the target?
That way we can see if the table entry was right.
> wkr,
> Thomas.
> >> Regards,
> >> Aitor
> embedded brains GmbH
> Thomas Doerfler Obere Lagerstr. 30
> D-82178 Puchheim Germany
> Tel. : +49-89-18 90 80 79-2
> Fax : +49-89-18 90 80 79-9
> email: Thomas.Doerfler at embedded-brains.de
> PGP public key available on request
> rtems-users mailing list
> rtems-users at rtems.com <mailto:rtems-users at rtems.com>
