--wrap ld functionality does not work with Init RTEMS function
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Apr 8 17:53:55 UTC 2008
Thomas Dörfler wrote:
> Hi,
> Joel Sherrill schrieb:
>> Aitor.Viana.Sanchez at esa.int wrote:
>>> Hi all,
>>> does anybody knows why when trying to wrap the Init RTEMS function
>>> with the ld --wrap functionality everything compiles well but
>>> eventually the wrapper function is not executed?
>>> Maybe I am missing something, but is taking me a while to discover why.
>> Init is a task/thread and threads will not return to the wrapper.
>> They are entered but exit via rtems_task_delete or pthread_exit.
>> I would expect the wrapper to be entered, then Init but no return
>> from Init.
> Normally Init will be referenced from within the same module: The
> "init.c" module contains the first task AND the default list in init
> tasks (somehwere deep down in system.h -> confdefs.h). And therefore I
> would expect that the pointer in the list of init tasks will point to
> the REAL function, no matter how it might have been renamed.
> Does this make sense?
Hmmm.. that is also a distinct possibility. I wonder if --wrap
takes into account indirect function pointers.
It does appear to work though. See the attachment I compiled
natively like this:
gcc -o wrapped wrapped.c -Wl,--wrap=malloc && ./wrapped
I think wrapping thread bodies is the issue. No execution flow
out of the body.
--joel
> wkr,
> Thomas.
>>> Regards,
>>> Aitor
> embedded brains GmbH
> Thomas Doerfler Obere Lagerstr. 30
> D-82178 Puchheim Germany
> Tel. : +49-89-18 90 80 79-2
> Fax : +49-89-18 90 80 79-9
> email: Thomas.Doerfler at embedded-brains.de
> PGP public key available on request
Type: text/x-csrc
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20080408/dfa1ada8/attachment-0001.bin>
