More build oddities
Nigel Spon
nigel at adi.co.nz
Thu Apr 10 02:41:37 UTC 2008
On 08/04/2008, at 12:15 AM, Ralf Corsepius wrote:
> Another point: The auto*tools require a POSIX-compliant shell and
> try to
> guess upon which POSIX-compliant shells might be installed on a
> system.
> Here, the OP mentions to be using tcsh (a non-POSIX compliant)
> shell, ... leaves room for issues circulating around $SHELL,
> $CONFIG_SHELL and broken environments.
I had hoped I was avoiding exactly this kind of trouble by using a
bash script to invoke the RTEMS make, but perhaps this is not enough.
I actually have two scripts, the first builds the toolchain and
configures RTEMS, the second builds RTEMS itself. The split is because
I want to develop a BSP. The first script (which works, strangely
enough), is:
#!/bin/bash
# Top-level toolchain build & configure script for RTEMS 4.8
# This script assumes the XCode project directory is in the top-level
RTEMS directory
# It assumes it will find specific versions of binutils,gcc,and rtems
source in the ../tools directory
# It will build the toolchain and configure RTEMS in the XCode Build~~
subdirectory
# This may take some time....
CPU=powerpc
RTEMS_VERSION=4.8
BINUTILS_VERSION=2.17
GCC_VERSION=4.1.1
TARGET=$CPU-rtems$RTEMS_VERSION
TOPDIR=$PROJECT_DIR/..
TOOLDIR=$TOPDIR/tools
cd $BUILD_ROOT
if [ ! -e bin ]
then
echo "\n\nBuilding binutils..."
mkdir b-binutils
cd b-binutils
$TOOLDIR/binutils-$BINUTILS_VERSION/configure --target=$TARGET --
prefix=$BUILD_ROOT
make all
make info
make install
fi
PATH=$PATH:$BUILD_ROOT/bin
cd $BUILD_ROOT
if [ ! -e bin/$TARGET-gcc ]
then
echo "\n\n\nBuilding gcc"
mkdir b-gcc
cd b-gcc
$TOOLDIR/gcc-$GCC_VERSION/configure --target=$TARGET --prefix=
$BUILD_ROOT \
--with-gnu-as --with-gnu-ld --with-newlib --verbose --enable-
threads --enable-languages="c,c++"
make all
make info
make install
fi
cd $BUILD_ROOT
if [ ! -e b-rtems ]
then
echo "\n\n\nConfiguring RTEMS"
mkdir b-rtems
cd b-rtems
$TOOLDIR/rtems-4.8.0/configure --target=$TARGET --prefix=$BUILD_ROOT
--disable-sim --enable-cxx
fi
echo "Done!"
The second script, which isn't working, does:
#!/bin/bash
# RTEMS build script
BSP=virtex
cd $BUILD_ROOT
if [ -e b-rtems ]
then
PATH="$BUILD_ROOT/bin:$PATH"
export PATH
cd b-rtems
make RTEMS_BSP="$BSP" all install
else
echo "No b-rtems directory! Build the MakeTools target"
fi
"Its only a model."
Michael Hamel
ADInstruments Ltd, Dunedin, NZ
