Intermixing source code with disassembly
Fri Apr 11 03:02:14 UTC 2008
Ralf Corsepius wrote:
> On Fri, 2008-04-11 at 10:14 +0800, Teng Chee Wan Philip wrote:
>> Thanks, Chris. :)
>> I got it working now, after changing the code to unix line termination.
> IMO, it would be appropriate for you to report this issue to the
> binutils' list (binutils at sourceware.org) to have upstream a look at it.
> I don't know which OS you are using, but I am inclined to consider this
> to be a host-specific (cygwin/mingw?) bug in the objdump you are using.
I agree and will when I return in a couple of weeks. I would like to look into
the problem a little first before making the post to make it is not something
I have done.
Regards
