Virtex BSP and configure questions
Thomas Doerfler
Thomas.Doerfler at embedded-brains.de
Fri Apr 11 16:57:52 UTC 2008
Hi Robert,
Robert S. Grimes schrieb:
> Hi Thomas and all,
> In the README, there is this statement:
> When this BSP should run on a different hardware, a path to the
> proper "xparameters.h" can be provided on the "configure" command line.
> Two (simple?) questions:
> 1. What is the syntax for this? (I forgot, and I can't seem to find
> it...)
as far as I reconstruct, the proper addition to configure is:
../rtems/configure --target=powerpc-rtems4.8 .... \
RTEMS_XPARAMETERS_H=/my/path/to/the/edk/generated/file/x_parameters.h
> 2. Given that I've already built RTEMS, how can I determine what
> options were used for configure?
in your build-directory (which you hopefully did not delete), you will
find the "config.status" and "config.log" files. Both contain a copy of
the configure command line you entered.
wkr,
Thomas.
> Thanks!
> -Bob
embedded brains GmbH
Thomas Doerfler Obere Lagerstr. 30
D-82178 Puchheim Germany
Tel. : +49-89-18 90 80 79-2
Fax : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
