ZigBee
Paul Evans
paule at martexdesign.com
Sat Apr 12 20:41:27 UTC 2008
Hi,
I wanted to correct what I said about the license from Microchip. I went
back and looked. To use Microchip's code you need to use the Microchip
RF chip and a Microchip MCU.
There's a glimmer of hope though now that there's Microchip parts
running MIPS cores instead of the little Harvard architecture devices
they're known for. With enough memory I believe these devices would be
port candidates for RTEMS.
Best,
-Paul
Paul Evans wrote:
> Ralf Corsepius wrote:
>> On Fri, 2008-04-11 at 09:10 +0200, erki.szabolcs at itport.hu wrote:
>>> Hi,
>>> I'm sorry, if this is a discussed topic, but I'm new here and didn't find
>>> anything in RTEMS documentations. I decided to use RTEMS for our embedded
>>> system and an important part of this hardware is a ZigBee chip so I will
>>> need a ZigBee protocoll stack. Is there any plan or demand to add ZigBee
>>> stack to RTEMS?
>> None in the public code and no plans that I am aware about.
>> Contributions, welcome ;)
> The last time I looked at Zigbee it looked expensive to do, hopefully
> I'm out of date and this has all changed:
> I think the Microchip Zigbee stack is the only "free" one out there in
> terms of code. It's license is not an open one in fact it's got a use
> with Microchip Products or else clause. So you'd want to stay clear of
> it. It probably wasn't that useful anyway, especially if there's any pic
> assembler in it. (If you are using a Microchip transceiver even with an
> different micro-- it's a good as good of as anything else to port to
> your platform/BSP for your own commercial use.)
> The standard itself isn't free either unless you're using it for
> "non-commercial" uses. I honestly don't know if contributing to an open
> source project and then using the results would be a commercial use.
> I'm not sure what the "Control4" company that linuxdevices.com finds
> uses but I suspect it's probably a commercial one. (I think a lot of
> early adopters may tend to use complete modules not chips as the analog
> stuff can be challenging-- which could be why there's not much code out
> there) It's the only other open source reference to Zigbee I see..
> Best,
> -Paul
>> Ralf
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
