ZigBee
erki.szabolcs at itport.hu
Mon Apr 14 06:58:43 UTC 2008
Hi,
Maybe using sources from manufacturers isn't the most useful way to
implement a ZigBee stack to RTEMS. AFAIK Texas Instruments has a ZigBee
stack too, but you can use it only with their SDK and chip, so it isn't a
widely usable solution. But there is some open source project which aim to
implement a fully open source stack. I'm not sure of stability an fullness
of their code-base. Check:
http://www.open-zb.net/
http://www.freaklabs.org/
and we can look into TinyOS ZigBee stack. This projects could help us not
to start from zero.
Br,
Szabolcs
On Szo, Április 12, 2008 10:41 pm, Paul Evans wrote:
> Hi,
> I wanted to correct what I said about the license from Microchip. I went
> back and looked. To use Microchip's code you need to use the Microchip RF
> chip and a Microchip MCU.
> There's a glimmer of hope though now that there's Microchip parts
> running MIPS cores instead of the little Harvard architecture devices
> they're known for. With enough memory I believe these devices would be
> port candidates for RTEMS.
> Best,
> -Paul
> Paul Evans wrote:
>> Ralf Corsepius wrote:
>>> On Fri, 2008-04-11 at 09:10 +0200, erki.szabolcs at itport.hu wrote:
>>>> Hi,
>>>> I'm sorry, if this is a discussed topic, but I'm new here and
>>>> didn't find anything in RTEMS documentations. I decided to use RTEMS
>>>> for our embedded system and an important part of this hardware is a
>>>> ZigBee chip so I will
>>>> need a ZigBee protocoll stack. Is there any plan or demand to add
>>>> ZigBee
>>>> stack to RTEMS?
>>> None in the public code and no plans that I am aware about.
>>> Contributions, welcome ;)
>> The last time I looked at Zigbee it looked expensive to do, hopefully
>> I'm out of date and this has all changed:
>> I think the Microchip Zigbee stack is the only "free" one out there in
>> terms of code. It's license is not an open one in fact it's got a use
>> with Microchip Products or else clause. So you'd want to stay clear of
>> it. It probably wasn't that useful anyway, especially if there's any
>> pic assembler in it. (If you are using a Microchip transceiver even with
>> an different micro-- it's a good as good of as anything else to port to
>> your platform/BSP for your own commercial use.)
>> The standard itself isn't free either unless you're using it for
>> "non-commercial" uses. I honestly don't know if contributing to an open
>> source project and then using the results would be a commercial use.
>> I'm not sure what the "Control4" company that linuxdevices.com finds
>> uses but I suspect it's probably a commercial one. (I think a lot of
>> early adopters may tend to use complete modules not chips as the analog
>> stuff can be challenging-- which could be why there's not much code
>> out there) It's the only other open source reference to Zigbee I see..
>> Best,
>> -Paul
>>> Ralf
>>> rtems-users mailing list rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
