Blackfin interrupt handling patches
    Allan Hessenflow
    allanh-rtems2 at kallisti.com
    Thu Aug 14 05:54:04 UTC 2008
Quite some time ago I was involved in a discussion on this list about
the Blackfin interrupt and context handling.  The gist was that the
existing code has some problems; I believed I have a fix but had not had
time to adequately test it.  I did provide it to another user at that
time but have not heard anything about any test results there, so I assume
he has not had time either.  Anyway, I've had another request for Blackfin
RTEMS info, and decided I'll go ahead and submit the changes.  I still
haven't had time to test it as thoroughly as I'd like, but I'm certain it
works better than the existing code in CVS.
The attached patch is against the cvs head as of a little earlier this
evening.
allan
Allan N. Hessenflow      allanh at kallisti.com
2008-08-13	Allan Hessenflow <allanh at kallisti.com>
	* cpu.c, cpu_asm.S, irq.c, rtems/score/cpu.h,
	rtems/score/cpu_asm.h: reworked interrupt handling to fix
	context switching.
Index: cpukit/score/cpu/bfin/cpu.c
RCS file: /usr1/CVS/rtems/cpukit/score/cpu/bfin/cpu.c,v
retrieving revision 1.6
diff -c -3 -p -r1.6 cpu.c
*** cpukit/score/cpu/bfin/cpu.c	17 Dec 2007 16:12:37 -0000	1.6
--- cpukit/score/cpu/bfin/cpu.c	14 Aug 2008 05:28:58 -0000
*** 30,35 ****
--- 30,42 ----
+ extern void _ISR15_Handler(void);
+ extern void _CPU_Emulation_handler(void);
+ extern void _CPU_Reset_handler(void);
+ extern void _CPU_NMI_handler(void);
+ extern void _CPU_Exception_handler(void);
+ extern void _CPU_Unhandled_Interrupt_handler(void);
  void _CPU_Initialize(
    void      (*thread_dispatch)      /* ignored on this CPU */
*************** void _CPU_Initialize(
*** 45,51 ****
     *  dependent variable.
!   _CPU_Thread_dispatch_pointer = thread_dispatch;
     *  If there is not an easy way to initialize the FP context
--- 52,58 ----
!   /*_CPU_Thread_dispatch_pointer = thread_dispatch;*/
*** 55,62 ****
--- 62,92 ----
    /* FP context initialization support goes here */
+   proc_ptr ignored;
+ #if 0
+   /* occassionally useful debug stuff */
+   int i;
+   _CPU_ISR_install_raw_handler(0, _CPU_Emulation_handler, &ignored);
+   _CPU_ISR_install_raw_handler(1, _CPU_Reset_handler, &ignored);
+   _CPU_ISR_install_raw_handler(2, _CPU_NMI_handler, &ignored);
+   _CPU_ISR_install_raw_handler(3, _CPU_Exception_handler, &ignored);
+   for (i = 5; i < 15; i++)
+     _CPU_ISR_install_raw_handler(i, _CPU_Unhandled_Interrupt_handler, &ignored);
+ #endif
+   /* install handler that will be used to call _Thread_Dispatch */
+   _CPU_ISR_install_raw_handler( 15, _ISR15_Handler, &ignored );
+   /* enable self nesting */
+   __asm__ __volatile__ ("syscfg = %0" : : "d" (0x00000004));
  /*PAGE
   *  _CPU_ISR_Get_level
*************** uint32_t   _CPU_ISR_Get_level( void )
*** 78,84 ****
      _tmpimask = *((uint32_t*)IMASK);
!     return _tmpimask;
  /*PAGE
--- 108,114 ----
!     return (_tmpimask & 0xffe0) ? 0 : 1;
  /*PAGE
*************** void _CPU_ISR_install_vector(
*** 136,150 ****
    proc_ptr   *old_handler
!    *old_handler = _ISR_Vector_table[ vector ];
!     *  If the interrupt vector table is a table of pointer to isr entry
!     *  points, then we need to install the appropriate RTEMS interrupt
!     *  handler for this vector number.
!    _CPU_ISR_install_raw_handler( vector, _ISR_Handler, old_handler );
      *  We put the actual user ISR address in '_ISR_vector_table'.  This will
--- 166,174 ----
!    proc_ptr ignored;
*** 152,159 ****
--- 176,194 ----
      _ISR_Vector_table[ vector ] = new_handler;
+     _CPU_ISR_install_raw_handler( vector, _ISR_Handler, &ignored );
+ #if (CPU_PROVIDES_IDLE_THREAD_BODY == TRUE)
+ void *_CPU_Thread_Idle_body(uint32_t ignored) {
+     while (1) {
+         __asm__ __volatile__("ssync; idle; ssync");
+ #endif
   * Copied from the arm port.
*************** void _CPU_Context_Initialize(
*** 170,181 ****
      stack_high = ((uint32_t  )(stack_base) + size);
      the_context->register_sp = stack_high;
-     // gcc/config/bfin/bfin.h defines CPU_MINIMUM_STACK_FRAME_SIZE = 0 thus we do sp=fp
-     // is this correct ?????
-     the_context->register_fp = stack_high;
      the_context->register_rets = (uint32_t) entry_point;
!     //mask the interrupt level
--- 205,212 ----
!     the_context->imask = new_level ? 0 : 0xffff;
Index: cpukit/score/cpu/bfin/cpu_asm.S
RCS file: /usr1/CVS/rtems/cpukit/score/cpu/bfin/cpu_asm.S,v
retrieving revision 1.4
diff -c -3 -p -r1.4 cpu_asm.S
*** cpukit/score/cpu/bfin/cpu_asm.S	10 Sep 2007 22:24:57 -0000	1.4
--- cpukit/score/cpu/bfin/cpu_asm.S	14 Aug 2008 05:28:58 -0000
*** 4,12 ****
   *  in the Blackfin port of RTEMS.  These algorithms must be implemented
   *  in assembly language
   *  Copyright (c) 2006 by Atos Automacao Industrial Ltda.
!  *             written by Alain Schaefer <alain.schaefer at easc.ch>
!  *                    and Antonio Giovanini <antonio at atos.com.br>
   *  The license and distribution terms for this file may be
   *  found in the file LICENSE in this distribution or at
--- 4,17 ----
+  *  Copyright (c) 2008 Kallisti Labs, Los Gatos, CA, USA
+  *             written by Allan Hessenflow <allanh at kallisti.com>
+  *  Based on earlier version:
*** 14,21 ****
   *  $Id: cpu_asm.S,v 1.4 2007/09/10 22:24:57 joel Exp $
  #include <rtems/asm.h>
  #include <rtems/score/cpu_asm.h>
  #include <rtems/score/bfin.h>
--- 19,26 ----
*** 24,29 ****
--- 29,229 ----
  #define LO(con32) ((con32) & 0xFFFF)
  #define HI(con32) (((con32) >> 16) & 0xFFFF)
+ #if 0
+ /* some debug routines */
+ 	.globl __CPU_write_char;
+ __CPU_write_char:
+ 	p0.h = 0xffc0;
+ 	p0.l = 0x0400;
+ txWaitLoop:
+ 	r1 = w[p0 + 0x14];
+ 	cc = bittst(r1, 5);
+ 	if !cc jump txWaitLoop;
+ 	w[p0 + 0x00] = r0;
+ 	rts;
+ 	.globl __CPU_write_crlf;
+ __CPU_write_crlf:
+ 	r0 = '\r';
+ 	[--sp] = rets;
+ 	call __CPU_write_char;
+ 	rets = [sp++];
+ 	r0 = '\n';
+ 	jump __CPU_write_char;
+ __CPU_write_space:
+ 	r0 = ' ';
+ 	.globl __CPU_write_nybble;
+ __CPU_write_nybble:
+ 	r1 = 0x0f;
+ 	r0 = r0 & r1;
+ 	r0 += '0';
+ 	r1 = '9';
+ 	cc = r0 <= r1;
+ 	if cc jump __CPU_write_char;
+ 	r0 += 'a' - '0' - 10;
+ 	.globl __CPU_write_byte;
+ __CPU_write_byte:
+ 	[--sp] = r0;
+ 	[--sp] = rets;
+ 	r0 >>= 4;
+ 	call __CPU_write_nybble;
+ 	rets = [sp++];
+ 	r0 = [sp++];
+ 	jump __CPU_write_nybble;
+ __CPU_write_chawmp:
+ 	[--sp] = r0;
+ 	[--sp] = rets;
+ 	r0 >>= 8;
+ 	call __CPU_write_byte;
+ 	rets = [sp++];
+ 	r0 = [sp++];
+ 	jump __CPU_write_byte;
+ __CPU_write_gawble:
+ 	[--sp] = r0;
+ 	[--sp] = rets;
+ 	r0 >>= 16;
+ 	call __CPU_write_chawmp;
+ 	rets = [sp++];
+ 	r0 = [sp++];
+ 	jump __CPU_write_chawmp;
+ __CPU_dump_registers:
+ 	[--sp] = rets;
+ 	[--sp] = r0;
+ 	[--sp] = r1;
+ 	[--sp] = p0;
+ 	r0 = [sp + 8];
+ 	call __CPU_write_gawble;
+ 	call __CPU_write_space;
+ 	r0 = [sp + 4];
+ 	r0 = r2;
+ 	r0 = r3;
+ 	r0 = r4;
+ 	r0 = r5;
+ 	r0 = r6;
+ 	r0 = r7;
+ 	call __CPU_write_crlf;
+ 	r0 = [sp];
+ 	r0 = p1;
+ 	r0 = p2;
+ 	r0 = p3;
+ 	r0 = p4;
+ 	r0 = p5;
+ 	r0 = fp;
+ 	r0 = sp;
+ 	r0 += 16;
+ 	p0 = [sp++];
+ 	r1 = [sp++];
+ 	r0 = [sp++];
+ 	rets = [sp++];
+ 	rts;
+ 	.globl __CPU_Exception_handler;
+ __CPU_Exception_handler:
+ 	usp = sp;
+ 	sp.h = 0xffb0;
+ 	sp.l = 0x1000;
+ 	[--sp] = (r7:0,p5:0);
+ 	r0 = 'x';
+ 	jump hcf;
+ 	.globl __CPU_Emulation_handler;
+ __CPU_Emulation_handler:
+ 	usp = sp;
+ 	sp.h = 0xffb0;
+ 	sp.l = 0x1000;
+ 	r0 = 'e';
+ 	jump hcf;
+ 	.globl __CPU_Reset_handler;
+ __CPU_Reset_handler:
+ 	usp = sp;
+ 	sp.h = 0xffb0;
+ 	sp.l = 0x1000;
+ 	r0 = 'r';
+ 	jump hcf;
+ 	.globl __CPU_NMI_handler;
+ __CPU_NMI_handler:
+ 	usp = sp;
+ 	sp.h = 0xffb0;
+ 	sp.l = 0x1000;
+ 	r0 = 'n';
+ 	jump hcf;
+ 	.globl __CPU_Unhandled_Interrupt_handler;
+ __CPU_Unhandled_Interrupt_handler:
+ 	usp = sp;
+ 	sp.h = 0xffb0;
+ 	sp.l = 0x1000;
+ 	r0 = 'i';
+ 	p0.h = HI(IPEND);
+ 	p0.l = LO(IPEND);
+ 	r0 = [p0];
+ 	jump hcf;
+ hcf:
+ 	idle;
+ 	jump hcf;
+ #endif
  /*  _CPU_Context_switch
   *  This routine performs a normal non-FP context switch.
*** 31,217 ****
   *  bfin Specific Information:
   *  For now we simply save all registers.
! .globl __CPU_Context_switch
  __CPU_Context_switch:
!     /* Start saving context R0 = current, R1=heir */
!     /*save P0 first*/
!     [FP+0x8] = P0;
!     P0 = R0;
!     [ P0 + R0_OFFSET ] = R0;
!     [ P0 + R1_OFFSET] = R1;
!     [ P0 + R2_OFFSET] = R2;
!     [ P0 + R4_OFFSET] = R4;
!     [ P0 + R3_OFFSET] = R3;
!     [ P0 + R5_OFFSET] = R5;
!     [ P0 + R6_OFFSET] = R6;
!     [ P0 + R7_OFFSET] = R7;
!     [ P0 + P1_OFFSET] = P1;
!     /* save the original value of P0 */
!     P1 = [FP+0x8];
!     [ P0 + P0_OFFSET] = P1;
!     [ P0 + P2_OFFSET] = P2;
!     [ P0 + P3_OFFSET] = P3;
!     [ P0 + P4_OFFSET] = P4;
!     [ P0 + P5_OFFSET] = P5;
!     [ P0 + FP_OFFSET] = FP;
!     [ P0 + SP_OFFSET] = SP;
!     /* save ASTAT */
!     R0 = ASTAT;
!     [P0 + ASTAT_OFFSET] = R0;
!     /* save Loop Counters */
!     R0 = LC0;
!     [P0 + LC0_OFFSET] = R0;
!     R0 = LC1;
!     [P0 + LC1_OFFSET] = R0;
!     /* save Accumulators */
!     R0 = A0.W;
!     [P0 + A0W_OFFSET] = R0;
!     R0 = A0.X;
!     [P0 + A0X_OFFSET] = R0;
!     R0 = A1.W;
!     [P0 + A1W_OFFSET] = R0;
!     R0 = A1.X;
!     [P0 + A1X_OFFSET] = R0;
!     /* save Index Registers */
!     R0 = I0;
!     [P0 + I0_OFFSET] = R0;
!     R0 = I1;
!     [P0 + I1_OFFSET] = R0;
!     R0 = I2;
!     [P0 + I2_OFFSET] = R0;
!     R0 = I3;
!     [P0 + I3_OFFSET] = R0;
!     /* save Modifier Registers */
!     R0 = M0;
!     [P0 + M0_OFFSET] = R0;
!     R0 = M1;
!     [P0 + M1_OFFSET] = R0;
!     R0 = M2;
!     [P0 + M2_OFFSET] = R0;
!     R0 = M3;
!     [P0 + M3_OFFSET] = R0;
!     /* save Length Registers */
!     R0 = L0;
!     [P0 + L0_OFFSET] = R0;
!     R0 = L1;
!     [P0 + L1_OFFSET] = R0;
!     R0 = L2;
!     [P0 + L2_OFFSET] = R0;
!     R0 = L3;
!     [P0 + L3_OFFSET] = R0;
!     /* Base Registers */
!     R0 = B0;
!     [P0 + B0_OFFSET] = R0;
!     R0 = B1;
!     [P0 + B1_OFFSET] = R0;
!     R0 = B2;
!     [P0 + B2_OFFSET] = R0;
!     R0 = B3;
!     [P0 + B3_OFFSET] = R0;
!     /* save RETS */
!     R0 = RETS;
!     [ P0 + RETS_OFFSET] = R0;
  restore:
!     P0 = R1;
!     R1 = [P0 + R1_OFFSET];
!     R2 = [P0 + R2_OFFSET];
!     R3 = [P0 + R3_OFFSET];
!     R4 = [P0 + R4_OFFSET];
!     R5 = [P0 + R5_OFFSET];
!     R6 = [P0 + R6_OFFSET];
!     R7 = [P0 + R7_OFFSET];
!     P2 = [P0 + P2_OFFSET];
!     P3 = [P0 + P3_OFFSET];
!     P4 = [P0 + P4_OFFSET];
!     P5 = [P0 + P5_OFFSET];
!     /* might have to be placed more to the end */
!     FP = [P0 + FP_OFFSET];
!     SP = [P0 + SP_OFFSET];
!     /* save ASTAT */
!     R0 = [P0 + ASTAT_OFFSET];
!     ASTAT = R0;
!     R0 = [P0 + LC0_OFFSET];
!     LC0 = R0;
!     R0 = [P0 + LC1_OFFSET];
!     LC1 = R0;
!     R0 = [P0 + A0W_OFFSET];
!     A0.W = R0;
!     R0 = [P0 + A0X_OFFSET];
!     A0.X = R0;
!     R0 = [P0 + A1W_OFFSET];
!     A1.W = R0;
!     R0 = [P0 + A1X_OFFSET];
!     A1.X = R0;
!     R0 = [P0 + I0_OFFSET];
!     I0 = R0;
!     R0 = [P0 + I1_OFFSET];
!     I1 = R0;
!     R0 = [P0 + I2_OFFSET];
!     I2 = R0;
!     R0 = [P0 + I3_OFFSET];
!     I3 = R0;
!     R0 = [P0 + M0_OFFSET];
!     M0 = R0;
!     R0 = [P0 + M1_OFFSET];
!     M1 = R0;
!     R0 = [P0 + M2_OFFSET];
!     M2 = R0;
!     R0 = [P0 + M3_OFFSET];
!     M3 = R0;
!     R0 = [P0 + L0_OFFSET];
!     L0 = R0;
!     R0 = [P0 + L1_OFFSET];
!     L1 = R0;
!     R0 = [P0 + L2_OFFSET];
!     L2 = R0;
!     R0 = [P0 + L3_OFFSET];
!     L3 = R0;
!     R0 = [P0 + B0_OFFSET];
!     B0 = R0;
!     R0 = [P0 + B1_OFFSET];
!     B1 = R0;
!     R0 = [P0 + B2_OFFSET];
!     B2 = R0;
!     R0 = [P0 + B3_OFFSET];
!     B3 = R0;
!     /* restore RETS */
!     P1 = [P0 + RETS_OFFSET];
!     RETS = P1;
!     /* now restore the P1 + P0 */
!     P1 = [P0 + R1_OFFSET];
!     P0 = [P0 + P0_OFFSET];
!     rts;
   *  _CPU_Context_restore
--- 231,314 ----
! /* make sure this sequence stays in sync with the definition for
!    Context_Control in rtems/score/cpu.h */
! 	p0 = r0;
! 	[p0++] = r4;
! 	[p0++] = r5;
! 	[p0++] = r6;
! 	[p0++] = r7;
! 	/* save pointer registers */
! 	[p0++] = p3;
! 	[p0++] = p4;
! 	[p0++] = p5;
! 	[p0++] = fp;
! 	[p0++] = sp;
! 	/* save length registers */
! 	r0 = l0;
! 	[p0++] = r0;
! 	r0 = l1;
! 	[p0++] = r0;
! 	r0 = l2;
! 	[p0++] = r0;
! 	r0 = l3;
! 	[p0++] = r0;
! 	/* save rets */
! 	r0 = rets;
! 	[p0++] = r0;
! 	/* save IMASK */
! 	p1.h = HI(IMASK);
! 	p1.l = LO(IMASK);
! 	r0 = [p1];
! 	[p0++] = r0;
+ 	p0 = r1;
  restore:
! 	/* restore data registers */
! 	r4 = [p0++];
! 	r5 = [p0++];
! 	r6 = [p0++];
! 	r7 = [p0++];
! 	/* restore pointer registers */
! 	p3 = [p0++];
! 	p4 = [p0++];
! 	p5 = [p0++];
! 	fp = [p0++];
! 	sp = [p0++];
! 	/* restore length registers */
! 	r0 = [p0++];
! 	l0 = r0;
! 	r0 = [p0++];
! 	l1 = r0;
! 	r0 = [p0++];
! 	l2 = r0;
! 	r0 = [p0++];
! 	l3 = r0;
! 	/* restore rets */
! 	r0 = [p0++];
! 	rets = r0;
! 	/* restore IMASK */
! 	r0 = [p0++];
! 	p1.h = HI(IMASK);
! 	p1.l = LO(IMASK);
! 	[p1] = r0;
! 	rts;
*************** restore:
*** 226,419 ****
   *  none
! .globl __CPU_Context_restore
  __CPU_Context_restore:
!     jump restore;
! .globl __ISR_Thread_Dispatch
! __ISR_Thread_Dispatch:
!     .extern __Thread_Dispatch
!     R0.l = __Thread_Dispatch;
!     R0.h = __Thread_Dispatch;
!     /* Puts the address of th Thread_Dispatch function on Stack
!      * Where it will be restored to the RTI register
!     P0 = [FP];
!     /* save the old reti */
!     R1 = [P0+0xc];
!     [P0+0xc] = R0;
!      * Overwriting the RETS Register is save because Thread_Dispatch is
!      * disabled when we are between call/link or unlink/rts
!     [P0+0x8] = R1;
!     /* save old rets */
!     rts;
! .globl __ISR_Handler
  __ISR_Handler:
!     /* First of all check the Stackpointer and */
!     /* switch to Scratchpad if necessary        */
!     /* save P0 and R0 in the scratchpad */
!     USP = P0;
!     /* load base adress of scratchpad */
!     P0.H = HI(SCRATCH);
!     P0.L = LO(SCRATCH);
!  	[--SP] = ASTAT; /*  save cc flag*/
!     /* if SP is already inside the SCRATCHPAD */
!     CC=SP<P0 (iu)
!     if !CC jump continue;
!     /* set PO to top of scratchpad */
!     P0.h=HI(SCRATCH_TOP);
!     P0.l=LO(SCRATCH_TOP);
!     /*save the old SP*/
!     [P0] = SP;
!     /*P0 += -4;*/
!     /*set the new Stackpointer*/
!     SP = P0;
!     /*restore the old PO*/
!     /* The Stackpointer is now setup as we want */
!     continue:
!     /* restore P0 and save some context */
!     P0 = USP;
!     /* save some state on the isr stack (scratchpad), this enables interrupt nesting */
!     [--SP] = RETI;
!     [--SP] = RETS;
!     [--SP] = ASTAT;
!     [--SP] = FP;
!     FP = SP;
!     [--SP] = (R7:0, P5:0) ;
!     /* Context is saved, now check which Instruction we were executing
!      * If we were between a call and link or between a unlink and rts
!      * we have to disable Thread_Dispatch because correct restore of context after
!      * Thread_Dispatch would not be possible. */
!     P0 = RETI;
!     R0 = P0;
!     R0.L = 0x0000;
!     R1.H = 0xffa0;
!     R1.L = 0x0000;
!     CC = R0 == R1;
!     if CC jump disablethreaddispatch;
!     R0 = W[P0](Z);
!     /* shift 16 bits to the right (select the high nibble ) */
!     /*R0 >>= 16;*/
!     R3 = 0;
!     /* Check if RETI is a LINK instruction */
!     R1.h = HI(0x0000);
!     R1.l = LO(0xE800);
!     CC=R0==R1;
!     if cc jump disablethreaddispatch;
!     /* Check if RETI is a RTS instruction */
!     R1.l = LO(0x0010);
!     CC=R0==R1;
!     jump afterthreaddispatch;
!     disablethreaddispatch:
!     /*  _Thread_Dispatch_disable_level++   */
!     .extern _Thread_Dispatch_disable_level
!     P0.H = __Thread_Dispatch_disable_level;
!     P0.L = __Thread_Dispatch_disable_level;
!     R0 = [P0];
!     R0 += 1;
!     [P0] = R0;
!     R3 = 1;
!     afterthreaddispatch:
!     /* Put R3 on the stack */
!     [--SP] = R3;
!     /* Obtain a bitlist of the pending interrupts. */
!     P0.H = HI(IPEND);
!     P0.L = LO(IPEND);
!     R1 = [P0];
!      * Search through the bit list stored in R0 to find the first enabled
!      * bit. The offset of this bit is the index of the interrupt that is
!      * to be handled.
!     R0 = -1;
!     intloop:
!         R0 += 1;
!         R1 = ROT R1 by -1;
!         if !cc jump intloop;
!     /* pass SP as parameter to the C function */
!     R1 = SP
!     /* pass values by register as well as by stack */
!     /* to comply with the c calling conventions    */
!     [--SP] = R0;
!     [--SP] = R1;
!     .extern _ISR_Handler2
!     call    _ISR_Handler2
!     /* inc 2 to compensate the passing of arguments */
!     R3 = [SP++];
!     R3 = [SP++];
!     /* check if _Thread_Dispatch_disable_level has been incremented */
!     R3 = [SP++]
!     CC=R3==0
!     if cc jump dont_decrement;
!     R0 = [P0];
!     R0 += -1;
!     [P0] = R0;
!     dont_decrement:
!     (R7:0, P5:0) = [SP++];
!     FP =    [SP++];
!     ASTAT = [SP++];
!     RETS =  [SP++];
!     RETI =  [SP++];
!     /* Interrupts are now disabled again */
!     /*should restore the old stack !!!*/
!     /*if sp now points to SCRATCH_TOP */
!     USP = P0;
!     P0.H = HI(SCRATCH_TOP);
!     P0.L = LO(SCRATCH_TOP);
!     CC=SP==P0
!     if !cc jump restoreP0
!     /* restore the stack */
!     SP=[P0];
!     restoreP0:
!     P0 = USP;
!     ASTAT = [SP++]; /* restore cc flag */
!     /*now we should be on the old "user-stack" again */
!     /* return from interrupt, will jump to adress stored in RETI */
!     RTI;
--- 323,598 ----
   *  none
! 	p0 = r0;
! 	jump restore;
! 	.extern __CPU_Interrupt_stack_high;
! 	.extern __ISR_Nest_level
! 	.extern __Thread_Dispatch_disable_level
! 	.extern __Context_Switch_necessary
! 	.extern __ISR_Signals_to_thread_executing
  __ISR_Handler:
! 	/* all interrupts are disabled at this point */
! 	/* the following few items are pushed onto the task stack for at
! 	   most one interrupt; nested interrupts will be using the interrupt
! 	   stack for everything. */
! 	[--sp] = astat;
! 	[--sp] = p1;
! 	[--sp] = p0;
! 	[--sp] = r1;
! 	[--sp] = r0;
! 	p0.h = __ISR_Nest_level;
! 	p0.l = __ISR_Nest_level;
! 	r0 = [p0];
! 	r0 += 1;
! 	[p0] = r0;
! 	cc = r0 <= 1 (iu);
! 	if !cc jump noStackSwitch;
! 	/* setup interrupt stack */
! 	r0 = sp;
! 	p0.h = __CPU_Interrupt_stack_high;
! 	p0.l = __CPU_Interrupt_stack_high;
! 	sp = [p0];
! 	[--sp] = r0;
! noStackSwitch:
! 	/* disable thread dispatch */
! 	p0.h = __Thread_Dispatch_disable_level;
! 	p0.l = __Thread_Dispatch_disable_level;
! 	r0 = [p0];
! 	r0 += 1;
! 	[p0] = r0;
! 	[--sp] = reti;	/* interrupts are now enabled */
! 	/* figure out what vector we are */
! 	p0.h = HI(IPEND);
! 	p0.l = LO(IPEND);
! 	r1 = [p0];
! 	/* we should only get here for events that require RTI to return */
! 	r1 = r1 >> 5;
! 	r0 = 4;
! 	/* at least one bit must be set, so this loop will exit */
! vectorIDLoop:
! 	r0 += 1;
! 	r1 = rot r1 by -1;
! 	if !cc jump vectorIDLoop;
! 	[--sp] = r2;
! 	p0.h = __ISR_Vector_table;
! 	p0.l = __ISR_Vector_table;
! 	r2 = [p0];
! 	r1 = r0 << 2;
! 	r1 = r1 + r2;
! 	p0 = r1;
! 	p0 = [p0];
! 	cc = p0 == 0;
! 	if cc jump noHandler;
! 	/* r2, r0, r1, p0, p1, astat are already saved */
! 	[--sp] = a1.x;
! 	[--sp] = a1.w;
! 	[--sp] = a0.x;
! 	[--sp] = a0.w;
! 	[--sp] = r3;
! 	[--sp] = p3;
! 	[--sp] = p2;
! 	[--sp] = lt1;
! 	[--sp] = lt0;
! 	[--sp] = lc1;
! 	[--sp] = lc0;
! 	[--sp] = lb1;
! 	[--sp] = lb0;
! 	[--sp] = i3;
! 	[--sp] = i2;
! 	[--sp] = i1;
! 	[--sp] = i0;
! 	[--sp] = m3;
! 	[--sp] = m2;
! 	[--sp] = m1;
! 	[--sp] = m0;
! 	[--sp] = l3;
! 	[--sp] = l2;
! 	[--sp] = l1;
! 	[--sp] = l0;
! 	[--sp] = b3;
! 	[--sp] = b2;
! 	[--sp] = b1;
! 	[--sp] = b0;
! 	[--sp] = rets;
! 	r1 = fp; /* is this really what should be passed here? */
! 	/* call user isr; r0 = vector number, r1 = frame pointer */
! 	sp += -12; /* bizarre abi... */
! 	call (p0);
! 	sp += 12;
! 	rets = [sp++];
! 	b0 = [sp++];
! 	b1 = [sp++];
! 	b2 = [sp++];
! 	b3 = [sp++];
! 	l0 = [sp++];
! 	l1 = [sp++];
! 	l2 = [sp++];
! 	l3 = [sp++];
! 	m0 = [sp++];
! 	m1 = [sp++];
! 	m2 = [sp++];
! 	m3 = [sp++];
! 	i0 = [sp++];
! 	i1 = [sp++];
! 	i2 = [sp++];
! 	i3 = [sp++];
! 	lb0 = [sp++];
! 	lb1 = [sp++];
! 	lc0 = [sp++];
! 	lc1 = [sp++];
! 	lt0 = [sp++];
! 	lt1 = [sp++];
! 	p2 = [sp++];
! 	p3 = [sp++];
! 	r3 = [sp++];
! 	a0.w = [sp++];
! 	a0.x = [sp++];
! 	a1.w = [sp++];
! 	a1.x = [sp++];
! noHandler:
! 	r2 = [sp++];
! 	/* this disables interrupts again */
! 	reti = [sp++];
! 	r0 = [p0];
! 	r0 += -1;
! 	[p0] = r0;
! 	cc = r0 == 0;
! 	if !cc jump noStackRestore;
! 	sp = [sp];
! noStackRestore:
! 	/* check this stuff to insure context_switch_necessary and
! 	   isr_signals_to_thread_executing are being handled appropriately. */
! 	r0 = [p0];
! 	r0 += -1;
! 	[p0] = r0;
! 	cc = r0 == 0;
! 	if !cc jump noDispatch
! 	/* do thread dispatch if necessary */
! 	p0.h = __Context_Switch_necessary;
! 	p0.l = __Context_Switch_necessary;
! 	r0 = [p0];
! 	cc = r0 == 0;
! 	p0.h = __ISR_Signals_to_thread_executing;
! 	p0.l = __ISR_Signals_to_thread_executing;
! 	if !cc jump doDispatch
! 	r0 = [p0];
! 	cc = r0 == 0;
! 	if cc jump noDispatch
! doDispatch:
! 	r0 = 0;
! 	[p0] = r0;
! 	raise 15;
! noDispatch:
! 	r0 = [sp++];
! 	r1 = [sp++];
! 	p0 = [sp++];
! 	p1 = [sp++];
! 	astat = [sp++];
! 	rti
! /* the approach here is for the main interrupt handler, when a dispatch is
!    wanted, to do a "raise 15".  when the main interrupt handler does its
!    "rti", the "raise 15" takes effect and we end up here.  we can now
!    safely call _Thread_Dispatch, and do an "rti" to get back to the
!    original interrupted function.  this does require self-nesting to be
!    enabled; the maximum nest depth is the number of tasks. */
! 	.global __ISR15_Handler
! __ISR15_Handler:
! 	[--sp] = reti;
! 	[--sp] = rets;
! 	[--sp] = astat;
! 	[--sp] = a1.x;
! 	[--sp] = a1.w;
! 	[--sp] = a0.x;
! 	[--sp] = a0.w;
! 	[--sp] = r3;
! 	[--sp] = r2;
! 	[--sp] = r1;
! 	[--sp] = r0;
! 	[--sp] = p3;
! 	[--sp] = p2;
! 	[--sp] = p1;
! 	[--sp] = p0;
! 	[--sp] = lt1;
! 	[--sp] = lt0;
! 	[--sp] = lc1;
! 	[--sp] = lc0;
! 	[--sp] = lb1;
! 	[--sp] = lb0;
! 	[--sp] = i3;
! 	[--sp] = i2;
! 	[--sp] = i1;
! 	[--sp] = i0;
! 	[--sp] = m3;
! 	[--sp] = m2;
! 	[--sp] = m1;
! 	[--sp] = m0;
! 	[--sp] = l3;
! 	[--sp] = l2;
! 	[--sp] = l1;
! 	[--sp] = l0;
! 	[--sp] = b3;
! 	[--sp] = b2;
! 	[--sp] = b1;
! 	[--sp] = b0;
! 	call __Thread_Dispatch;
! 	sp += 12;
! 	b0 = [sp++];
! 	b1 = [sp++];
! 	b2 = [sp++];
! 	b3 = [sp++];
! 	l0 = [sp++];
! 	l1 = [sp++];
! 	l2 = [sp++];
! 	l3 = [sp++];
! 	m0 = [sp++];
! 	m1 = [sp++];
! 	m2 = [sp++];
! 	m3 = [sp++];
! 	i0 = [sp++];
! 	i1 = [sp++];
! 	i2 = [sp++];
! 	i3 = [sp++];
! 	lb0 = [sp++];
! 	lb1 = [sp++];
! 	lc0 = [sp++];
! 	lc1 = [sp++];
! 	lt0 = [sp++];
! 	lt1 = [sp++];
! 	p0 = [sp++];
! 	p1 = [sp++];
! 	p2 = [sp++];
! 	p3 = [sp++];
! 	r0 = [sp++];
! 	r1 = [sp++];
! 	r2 = [sp++];
! 	r3 = [sp++];
! 	a0.w = [sp++];
! 	a0.x = [sp++];
! 	a1.w = [sp++];
! 	a1.x = [sp++];
! 	astat = [sp++];
! 	rets = [sp++];
! 	reti = [sp++];
! 	rti;
Index: cpukit/score/cpu/bfin/irq.c
RCS file: /usr1/CVS/rtems/cpukit/score/cpu/bfin/irq.c,v
retrieving revision 1.3
diff -c -3 -p -r1.3 irq.c
*** cpukit/score/cpu/bfin/irq.c	17 Dec 2007 16:12:37 -0000	1.3
--- cpukit/score/cpu/bfin/irq.c	14 Aug 2008 05:28:58 -0000
*** 11,16 ****
--- 11,18 ----
   *  $Id: irq.c,v 1.3 2007/12/17 16:12:37 joel Exp $
+ #if 0 /* this file no longer used */
  #include <rtems/score/cpu.h>
*************** uint32_t SIC_IAR_Value ( uint8_t Vector
*** 104,106 ****
--- 106,111 ----
        return 0x88888888;
+ #endif /* 0 */
Index: cpukit/score/cpu/bfin/rtems/score/cpu.h
RCS file: /usr1/CVS/rtems/cpukit/score/cpu/bfin/rtems/score/cpu.h,v
retrieving revision 1.12
diff -c -3 -p -r1.12 cpu.h
*** cpukit/score/cpu/bfin/rtems/score/cpu.h	31 Jul 2008 14:55:34 -0000	1.12
--- cpukit/score/cpu/bfin/rtems/score/cpu.h	14 Aug 2008 05:28:59 -0000
*************** extern "C" {
*** 105,111 ****
   *  XXX document implementation including references if appropriate
! #define CPU_HAS_SOFTWARE_INTERRUPT_STACK FALSE
   *  Does the CPU follow the simple vectored interrupt model?
--- 105,124 ----
! #define CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE
!  *  Does the CPU follow the simple vectored interrupt model?
!  *  If TRUE, then RTEMS allocates the vector table it internally manages.
!  *  If FALSE, then the BSP is assumed to allocate and manage the vector
!  *  table
!  *  BFIN Specific Information:
!  *  XXX document implementation including references if appropriate
! #define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
*** 152,158 ****
! #define CPU_ALLOCATE_INTERRUPT_STACK FALSE
   *  Does the RTEMS invoke the user's ISR with the vector number and
--- 165,171 ----
! #define CPU_ALLOCATE_INTERRUPT_STACK TRUE
*** 305,311 ****
! #define CPU_PROVIDES_IDLE_THREAD_BODY    FALSE
   *  Does the stack grow up (toward higher addresses) or down
--- 318,324 ----
! #define CPU_PROVIDES_IDLE_THREAD_BODY    TRUE
*** 453,541 ****
   *  that must be saved during a voluntary context switch from one thread
   *  to another.
  typedef struct {
-     /* we are saving all registers, maybe we should not */
-     uint32_t   register_r0;
-     uint32_t   register_r1;
-     uint32_t   register_r2;
-     uint32_t   register_r3;
      uint32_t   register_r4;
      uint32_t   register_r5;
      uint32_t   register_r6;
      uint32_t   register_r7;
!     uint32_t   register_p0;
!     uint32_t   register_p1;
!     uint32_t   register_p2;
      uint32_t   register_p3;
      uint32_t   register_p4;
      uint32_t   register_p5;
      uint32_t   register_fp;
      uint32_t   register_sp;
-     uint32_t   register_i0;
-     uint32_t   register_i1;
-     uint32_t   register_i2;
-     uint32_t   register_i3;
-     uint32_t   register_m0;
-     uint32_t   register_m1;
-     uint32_t   register_m2;
-     uint32_t   register_m3;
-     uint32_t   register_b0;
-     uint32_t   register_b1;
-     uint32_t   register_b2;
-     uint32_t   register_b3;
      uint32_t   register_l0;
      uint32_t   register_l1;
      uint32_t   register_l2;
      uint32_t   register_l3;
-     uint32_t   register_a0dotx;
-     uint32_t   register_a0dotw;
-     uint32_t   register_a1dotx;
-     uint32_t   register_a1dotw;
-     uint32_t   register_astat;
      uint32_t   register_rets;
!     uint32_t   register_lc0;
!     uint32_t   register_lt0;
!     uint32_t   register_lb0;
!     uint32_t   register_lc1;
!     uint32_t   register_lt1;
!     uint32_t   register_lb1;
!   /*BFIN_CYCLES_REGNUM,
!   BFIN_CYCLES2_REGNUM, */
!     uint32_t   register_usp;
!     uint32_t   register_seqstat;
!     uint32_t   register_syscfg;
!     uint32_t   register_reti;
!     uint32_t   register_retx;
!     uint32_t   register_retn;
!     uint32_t   register_rete;
!     uint32_t   register_pc;
!   Pseudo Registers
!   BFIN_PC_REGNUM,
!   BFIN_CC_REGNUM,
!   BFIN_EXTRA1,       Address of .text section.
!   BFIN_EXTRA2,       Address of .data section.
!   BFIN_EXTRA3,       Address of .bss section.
!   BFIN_FDPIC_EXEC_REGNUM,
!   BFIN_FDPIC_INTERP_REGNUM,
!   MMRs
!   BFIN_IPEND_REGNUM,
!   LAST ENTRY SHOULD NOT BE CHANGED.
!   BFIN_NUM_REGS      The number of all registers.
  } Context_Control;
  #define _CPU_Context_Get_SP( _context ) \
--- 466,494 ----
   *  to another.
+ /* make sure this stays in sync with the assembly function
+    __CPU_Context_switch in cpu_asm.S  */
  typedef struct {
!     uint32_t   imask;
  } Context_Control;
*************** SCORE_EXTERN void               *_CPU_In
*** 624,630 ****
! SCORE_EXTERN void           (*_CPU_Thread_dispatch_pointer)();
   *  Nothing prevents the porter from declaring more CPU specific variables.
--- 577,583 ----
! /* SCORE_EXTERN void           (*_CPU_Thread_dispatch_pointer)();*/
*************** SCORE_EXTERN void           (*_CPU_Threa
*** 790,798 ****
  #define _CPU_ISR_Disable( _level ) \
!        asm volatile ("cli %0 \n"       \
!                 : "=d" (_level) );     \
--- 743,749 ----
!        asm volatile ("cli %0 \n" : "=d" (_level) );     \
*** 808,817 ****
! #define _CPU_ISR_Enable( _level )  \
!     asm volatile ("STI %0 \n"                  \
!                    : : "d" (_level) );         \
--- 759,766 ----
! #define _CPU_ISR_Enable( _level ) { \
!     __asm__ __volatile__ ("sti %0 \n" : : "d" (_level) );   \
*** 827,839 ****
! #define _CPU_ISR_Flash( _level )
!     asm volatile ("cli %0;\n"          \
!                   "ssync; \n"           \
!                   "sti %1; \n"          \
!                    : "=r" (_level) : "0"(_level) );  \
   *  @ingroup CPUInterrupt
--- 776,785 ----
! #define _CPU_ISR_Flash( _level ) { \
!     __asm__ __volatile__ ("sti %0; ssync; sti %1" \
!                           : : "d"(0xffff), "d"(_level)); \
*** 854,862 ****
  #define _CPU_ISR_Set_level( _new_level ) \
!     if ( _new_level ) asm volatile ( "cli R0;" : : : "R0" ); \
!     else              asm volatile ( "R0.l = 0xFFFF;\n"\
!                                      "sti R0;" : : : "R0" ); \
--- 800,806 ----
!     __asm__ __volatile__ ( "sti %0" : : "d"(_new_level ? 0 : 0xffff) ); \
*** 1001,1008 ****
      asm volatile ( "cli R1; \
                      R1 = %0; \
                      _halt: \
                      jump _halt;"\
!                     : "=r" (_error) ); \
  /* end of Fatal Error manager macros */
--- 945,953 ----
                      R1 = %0; \
                      _halt: \
+                     idle; \
                      jump _halt;"\
!                     : : "r" (_error) ); \
Index: cpukit/score/cpu/bfin/rtems/score/cpu_asm.h
RCS file: /usr1/CVS/rtems/cpukit/score/cpu/bfin/rtems/score/cpu_asm.h,v
retrieving revision 1.2
diff -c -3 -p -r1.2 cpu_asm.h
*** cpukit/score/cpu/bfin/rtems/score/cpu_asm.h	17 Dec 2007 16:12:37 -0000	1.2
--- cpukit/score/cpu/bfin/rtems/score/cpu_asm.h	14 Aug 2008 05:28:59 -0000
*** 20,88 ****
  #ifndef _RTEMS_SCORE_CPU_ASM_H
  #define _RTEMS_SCORE_CPU_ASM_H
- /* offsets for the registers in the thread context */
- #define R0_OFFSET     0
- #define R1_OFFSET     4
- #define R2_OFFSET     8
- #define R3_OFFSET     12
- #define R4_OFFSET     16
- #define R5_OFFSET     20
- #define R6_OFFSET     24
- #define R7_OFFSET     28
- #define P0_OFFSET     32
- #define P1_OFFSET     36
- #define P2_OFFSET     40
- #define P3_OFFSET     44
- #define P4_OFFSET     48
- #define P5_OFFSET     52
- #define FP_OFFSET     56
- #define SP_OFFSET     60
- #define I0_OFFSET     64
- #define I1_OFFSET     68
- #define I2_OFFSET     72
- #define I3_OFFSET     76
- #define M0_OFFSET     80
- #define M1_OFFSET     84
- #define M2_OFFSET     88
- #define M3_OFFSET     92
- #define B0_OFFSET     96
- #define B1_OFFSET     100
- #define B2_OFFSET     104
- #define B3_OFFSET     108
- #define L0_OFFSET     112
- #define L1_OFFSET     116
- #define L2_OFFSET     120
- #define L3_OFFSET     124
- #define A0X_OFFSET     128
- #define A0W_OFFSET     132
- #define A1X_OFFSET     136
- #define A1W_OFFSET     140
- #define ASTAT_OFFSET   144
- #define RETS_OFFSET    148
- #define LC0_OFFSET     152
- #define LT0_OFFSET     156
- #define LB0_OFFSET     160
- #define LC1_OFFSET     164
- #define LT1_OFFSET     168
- #define LB1_OFFSET     172
- #define USP_OFFSET     174
- #define SEQSTAT_OFFSET 178
- #define SYSCFG_OFFSET  182
- #define RETI_OFFSET    184
- #define RETX_OFFSET    188
- #define RETN_OFFSET    192
- #define RETE_OFFSET    296
- #define PC_OFFSET      200
  #endif
--- 20,25 ----
