Blackfin port footprint bss > 500K ?
Allan Hessenflow allanh-rtems2 at kallisti.com
Sun Aug 17 20:11:54 UTC 2008
Devin Butterfield wrote:
> Is a 512K workspace really required for the bfin port? Can we make it
> smaller?
The BF537 Stamp BSP also reserves 512K for workspace, but that's only
because I copied that from the eZKit533 BSP.  The BF537 Stamp has quite
a bit of SDRAM so I had no reason to try reducing it.  However, I don't
see any reason the bfin ports should require more workspace than, say,
a 68K port, so I expect you could safely reduce it to be similar to
those.
allan
Allan N. Hessenflow      allanh at kallisti.com
