GDB partially works (for me)
Gene Smith gds at chartertn.net
Tue Aug 19 14:33:26 UTC 2008
My system now runs OK (networking, serial, timers etc) and runs the
test/demo programs OK and passes stress tests. If I set a breakpoint
before leaving start.S I can hit the breakpoint and do the usual stuff.
But if I try to continue after arriving at a breakpoint (such as at
Init), nothing works (no timer, no networking no serial) and all I see
happening is the idle task. Sometimes it will crash after (data abort
dump) this but usually just does idle loop.
I can look at all the registers that mask or turn off interrupts and
they look OK. So I am not sure what causes it to completely shut down or
go unstable after a b.p. is hit.
I do notice that sometimes I step into RTEMS code involving a watchdog
(watchdogtickle). Not sure how this is used or if it might be shutting
me down while at the breakpoint.
I get the same result with rtems4.8-gdb or insight. In both cases I am
using a Macraigor MPDemon jtag debugger box.
-gene
