GDB partially works (for me)
Gene Smith gds at chartertn.net
Tue Aug 19 16:16:45 UTC 2008
Steven Grunza wrote:
> Given the large number of boards and types of processors supported by
> RTEMS, we need more info about your environment.  Details such as CPU
> and board would be helpful.
Bsp is derived from csb337 arm. My actual processor is arm946es. I have
been looking at it a bit more and it appears that the timer interrupt
does continue to occur after hitting a breakpoint but eventually
_defaultExcHandler() from cpu.c is called. One time I saw
_ISR_Nest_level at 5 and it just printed "System Locked" message. Other
times it is zero and continuously prints that it is deleting the same
thread. In both cases the aborted PC address is 0x201a0da0 which is
_Watchdog_Sync_level in bss (not code!). So it goes into the weeds while
debugging/stepping.
Possibly interrupts need to be disabled while debugging/stepping?
Also, and I don't know if this is important, I see the message
in gdb "unsupport tag: DW_TAG_const_type" appear when I first load my
gdbinit (when starting gdb or insight or reloading with "so gdbinit").
>> -----Original Message-----
>> From: rtems-users-bounces at rtems.org
>> [mailto:rtems-users-bounces at rtems.org] On Behalf Of Gene Smith
>> Sent: Tuesday, August 19, 2008 10:33 AM
>> To: rtems-users at rtems.com
>> Subject: GDB partially works (for me)
>> My system now runs OK (networking, serial, timers etc) and
>> runs the test/demo programs OK and passes stress tests. If I
>> set a breakpoint before leaving start.S I can hit the
>> breakpoint and do the usual stuff.
>> But if I try to continue after arriving at a breakpoint (such
>> as at Init), nothing works (no timer, no networking no serial)
>> and all I see happening is the idle task. Sometimes it will
>> crash after (data abort
>> dump) this but usually just does idle loop.
>> I can look at all the registers that mask or turn off
>> interrupts and they look OK. So I am not sure what causes it
>> to completely shut down or go unstable after a b.p. is hit.
>> I do notice that sometimes I step into RTEMS code involving a
>> watchdog (watchdogtickle). Not sure how this is used or if it
>> might be shutting me down while at the breakpoint.
>> I get the same result with rtems4.8-gdb or insight. In both
>> cases I am using a Macraigor MPDemon jtag debugger box.
>> -gene
>> rtems-users mailing list
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
