intalling the rtems
roc bai
rtlinuxgpl at gmail.com
Fri Aug 22 01:18:07 UTC 2008
Hi,
all.
when I compile RTEMS-4.8.0, I get the below error infomation
gcc -B../../../../../posix/lib/ -specs bsp_specs -qrtems -D_BSD_SOURCE
-D_POSIX_C_SOURCE -O2 -g -o capture.exe init.o test1.o
../../../../../posix/lib/librtemscpu.a(mon-command.o): In function
`rtems_monitor_command_read':
/root/baishw/rtems/rtems480/c/posix/cpukit/libmisc/../../../../../rtems-4.8.0/c/src/../../cpukit/libmisc/monitor/mon-command.c:516:
warning: the `gets' function is dangerous and should not be used.
../../../../../posix/lib/librtemscpu.a(libscorecpu_a-cpu.o): In function
`cpy_jmpbuf':
/root/baishw/rtems/rtems480/c/posix/cpukit/score/cpu/unix/../../../../../../../rtems-4.8.0/c/src/../../cpukit/score/cpu/unix/cpu.c:498:
undefined reference to `trampo'
From the information, i think there is no trampo definition in the
library. But when i check the cpu.c file. The prototype of the routine is in
the file. So I want to know why i get the error, and how i do.
thanks ALL!
Best Regards!
Bai SHuwei
Email: baishuwei at gmail.com
Motto: Fighting For Freedom
URL: <http://lists.rtems.org/pipermail/users/attachments/20080822/686b5212/attachment.html>
