Bug of IMFS_unlink ?
Wei Shen
cquark at gmail.com
Sun Aug 24 20:24:58 UTC 2008
Hi,
I try to verify my supposition using code segments below.
(1)
mknod()
open()
close()
unlink()
(2)
mknod()
open()
unlink()
close()
IMFS_memfile_remove will be called to free related data structures when
deleting an IMFS memory file. I debugged the above code segments. In (1)
IMFS_memfile_remove is called; in (2) it is never called...
Maybe, we can clear the LIBIO_FLAGS_OPEN flag bit of "iop" in memfile_close
before memfile_check_rmnod.
And for device_close and imfs_dir_close, add similar checks.
> Looks to me that the generic close should be detecting this
> condition and (maybe) calling the specific filetype for unlink.
Since link count is recorded in jnode, we may only be able to check in each
filesystem.
Regards,
Wei
On 8/22/08, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> Wei Shen wrote:
>> I suspect there is a bug with unlink of IMFS files, but I am not certain.
>> If a file is still being opened, IMFS_unlink will not really free the
>> file node, but just decrements its link count and removes it from the
>> parent's chain, and the remaining work is leaved to close.
>> memfile_close calls memfile_check_rmnod to delete the file node with a
>> zero link count when the last user closes the file.
>> However, in memfile_check_rmnod "rtems_libio_is_file_open" is checked,
>> which it will always be TRUE because the LIBIO_FLAGS_OPEN flag bit has not
>> been cleared yet. Hence, the file node will never be deleted, while it can
>> no more be accessed in the file system.
> Can you provide a simple test case and let me analyze it?
>> I also wonder why device_close and imfs_dir_close do not do similar rmnod
>> checks as memfile_close.
> What do you think of that? Again I think it will take a test
> case to verify and fix.
URL: <http://lists.rtems.org/pipermail/users/attachments/20080825/a76dec9a/attachment-0001.html>
