Build Problems
Sun Aug 24 17:52:32 UTC 2008
Madhusudan C.S wrote:
> Hi all,
>           I had built RTEMS CVS Head using pre-built tools version 4.9
> using FC8 rpms, extracting debs using alien on my Ubuntu Gutsy
> machine, but after I did a fresh install to Hardy Heron,
> build is failing. This is the report generated, can someone help me ?
Standard questions and advice.  Build outside the source tree.  You
probably only
want to build 1 BSP and are building many.  You might be out of disk
space given
that.
Make sure you have the RTEMS autoconf and automake installed and at the
FRONT of your PATH.
cd rtems
./bootstrap
cd ..
mkdir b-sis
cd b-sis
../rtems/configure --target=sparc-rtems4.9 --enable-rtemsbsp=sis \
  --enable-tests=samples --prefix=SOME_DIRECTORY
make
That should work.
> Making preinstall in erc32
> make[8]: Entering directory
> `/media/professional/rtems/b-sis/sparc-rtems4.9/c/sis/lib/libbsp/sparc/erc32'
> make[8]: Nothing to be done for `preinstall'.
> make[8]: Leaving directory
> `/media/professional/rtems/b-sis/sparc-rtems4.9/c/sis/lib/libbsp/sparc'
> make[8]: Nothing to be done for `preinstall-am'.
> make[7]: Leaving directory
> make[7]: Entering directory
> `/media/professional/rtems/b-sis/sparc-rtems4.9/c/sis/lib/libbsp'
> make[7]: Nothing to be done for `preinstall-am'.
> make[6]: Leaving directory
> make[6]: Entering directory
> `/media/professional/rtems/b-sis/sparc-rtems4.9/c/sis/lib'
> make[6]: Nothing to be done for `preinstall-am'.
> make[5]: Leaving directory
> Making preinstall in libchip
> make[5]: Entering directory
> `/media/professional/rtems/b-sis/sparc-rtems4.9/c/sis/libchip'
> make[5]: *** No rule to make target `display/disp_hcms29xx.h', needed
> by `../../../sis/lib/include/libchip/disp_hcms29xx.h'.  Stop.
> make[4]: *** [preinstall-recursive] Error 1
> make[4]: Leaving directory
> `/media/professional/rtems/b-sis/sparc-rtems4.9/c/sis'
> make[3]: *** [preinstall-stamp] Error 2
> make[3]: Leaving directory
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> `/media/professional/rtems/b-sis/sparc-rtems4.9/c'
> make: *** [all-recursive] Error 1
> Thanks and regards,
> Madhusudan.C.S
> Blogs at: www.madhusudancs.info <http://www.madhusudancs.info>
