Little Endian ARM fails on 1st TCP datagram
Gene Smith
gds at chartertn.net
Mon Aug 18 14:01:35 UTC 2008
Gene Smith wrote:
> I am trying to bring up a new ARM bsp. ARP is working but when any TCP
> packet comes in it is dropped. With netdemo I see a TCP error:
> "Bad offset in TCP header"
> This is referring to the 4 bit header length field in the TCP header.
> Looking at the code with that parses this field, it either assumes big
> or little endian, depending on a BYTE_ORDER macro. It seems to be
> looking at it as big endian but my processor is definitely little.
> I am not sure where this is actually set. Looking around, it seems to
> depend on a defined value __ARMEL__ or __ARMEB__ which I can't find
> defined anywhere in the RTEMS tree.
> I did find a couple of mailing list threads that mention what seems like
> this problem, such as this:
> http://www.rtems.com/ml/rtems-users/2005/february/msg00232.html
> But it clains it is fixed in newlib-1.13 and rtems4.8 uses 1.15. So I am
> not sure if the problem has come back or was never really fixed or I am
> doing something else wrong.
> -gene
When I allow BYTE_ORDER to be redefined to LITTLE_ENDIAN in endian.h as
suggested in the above work around the problem goes away. I can now
connect and telnet into the netdemo app. So it appears that a problem
still exists, at least for my processor (arm946e-s).
-gene
