CVS Head Slushy, Please Test and Fix Warnings
Thu Aug 21 07:01:23 UTC 2008
Andrei Chichak wrote:
>> Please build the BSPs you use, fix warnings
>> and other issues.  Then report whether they
>> can run tests or not.
> I figured that I would give it a go. I got CVS going, grabbed the
> distribution, fired up MINGW and bootstrap blows since it needs
> autoconf 2.62. I grabbed the latest tools (17), installed them, but
> it still contains autoconf 2.61. No joy.
I followed the instructions in
http://wiki.filezilla-project.org/Compiling_FileZilla_3_under_Windows#Autotools
I installed M4 version 1.4.7 from the linked Sourceforge site.
Afterwards I configured Autoconf 2.62 and Automake 1.10.1 (downloaded
from GNU server) via 'configure --prefix=/opt/rtems-4.9' and installed
them directly into the RTEMS tree. With that done I was able to build
the current RTEMS CVS version from scratch.
> Thanks for all of your hard work though,
> Andrei
> rtems-users mailing list
> rtems-users at rtems.com
Sebastian Huber, Embedded Brains GmbH
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
PGP     : Public key available on request
